Sponsored by:
Sponsored by:
offfset?
Old 01-28-2007, 12:43 PM
Kaldar142
Kaldar142's Avatar
Default offfset?
what are the proper offsets on these cars to go with wheels such as 18x9 or 18x9.5 or 18x10?
i want them to look flush with my fender, what offsets do you guys recommend?
Kaldar142 is offline
Old 01-28-2007, 03:47 PM
Ford_Dude
Ford_Dude's Avatar
Default RE: offfset?
wow I need to know that as well the site I'm going to buy from has two offsets available
Ford_Dude is offline
Old 01-28-2007, 04:18 PM
drbobvs
drbobvs's Avatar
Flush with the fender? 18x9= about a 25mm offset, 18x10=about 35mm.
drbobvs is offline
Old 01-28-2007, 04:19 PM
drbobvs
drbobvs's Avatar
Here's 18x9 with 24mm offset.
[IMG]local://upfiles/16153/F5B78F682FA0438290E842B6A2A4BF38.jpg[/IMG]
[IMG]local://upfiles/16153/4C90D00ABE5C48E492AB95CAC1494150.jpg[/IMG]
drbobvs is offline
Old 01-31-2007, 07:19 PM
Kaldar142
Kaldar142's Avatar
so 20-30 offset should be fine?
Old 01-31-2007, 07:24 PM
drbobvs
drbobvs's Avatar
Again, you're talking about 2 different wheel widths you're putting on the front and back of the car, so you need different offsets if you want them to line up perfectly. If you don't mind the back sticking out more then you can go with a smaller (numerically lower) offset. My numbers in the first post are a rough estimate of perfection.
drbobvs is offline
Old 01-31-2007, 07:25 PM
torch red
torch red's Avatar
Mine are 38 mm front and 42 mm rear..
They seem perfect to me
[IMG]local://upfiles/19878/7B4350A566384A4FA8340ABE2B07FC1D.jpg[/IMG]
torch red is offline
Old 01-31-2007, 07:26 PM
torch red
torch red's Avatar
more
[IMG]local://upfiles/19878/FE34E3A8455B4C6FB87FDCF2EFA84B27.jpg[/IMG]
Old 02-01-2007, 01:02 AM
dkegel
dkegel's Avatar
ORIGINAL: drbobvs
Those sound more like pre-05 offset numbers. For an 18 x 9 or 10 the proper offset for the '05 -07 is usually 40 - 45mm I believe. Check out the Tire Rack site. It's a great source fortire sizing, offset, wheel weights, etc.
Dave Kegel
dkegel is offline
Old 02-01-2007, 01:11 AM
dkegel
dkegel's Avatar
Also check http://www.americanmuscle.com
They list 18 x 9 FR500wheels in 24mm offset for the 94-04 cars and 36mm offset for 05 - 07. Depending on the wheel, on the '05 and up I think you run the risk of insufficient caliper clearance with the smaller offset, especially in the front.
Dave Kegel
dkegel is offline
