Fuel quality in CA: Any tips?
RE: Fuel quality in CA: Any tips?
Any top-tier brand should work great ...
From Shell's website:
"Major auto manufacturers agree that a clean engine performs better. BMW, GM, Honda and Toyota have developed a TOP TIER Detergent Gasoline Standard that exceeds the EPA standards. TOP TIER Detergent Gasoline is a high-quality gasoline with enhanced cleaning power. It provides better protection against the build-up of carbon deposits on intake valves and fuel injectors, as compared to low- detergent gasolines ... There is a difference in the gasoline you choose."
see http://www.toptiergas.com/retailers.html for a list of brands that are top-tier. (Hmm .. BP, recommended by Ford, Is not on the list!)
Also: http://www.associatedcontent.com/art...s_you_use.html ... interesting write-up that talks about Ford and top-tier gas
Isn't this nice... in the article, it states that "None of the BP brands are listed as Top Tier."
How nice of Ford to print the BP advertising on my gas cap, encouraging the purchase of crappy gas...
ORIGINAL: SlowHand
Hey thanks for all the good advice, gents. @ 06GT4RAD, would you mind elaborating just a little re. the product in the link, i.e. what makes it better than anything else, how you've observed the results and how much and how often do you add it to your fuel? Many thanks.
The link I posted is Torco which is a High gradeUnleaded Fuel not really an additive. And if you use it as directed will increase your octane from a 91 to about a 105 Octane. This is not some cheap 2.99 a can additive but is actual high octane fuel. It would be the same as adding racing fuel to your tank from a pump only they sell it in cans. As for the results i myself have not used it but i do kow of many people that do and all have great results with it. As for how you add it you will add it each time you fill your tank as directed on the bottle. Here is a link to the FAQ's page go read it.
http://www.torco.com/index.php?fuseaction=home.faqs
http://www.torco.com/index.php?fusea...play&id=40
Richard
ORIGINAL: kenthicken
ORIGINAL: 07GTEddy
Chevron since day 1 with my 91 Brenspeed tune and mods to date and never a problem or a dull moment. [sm=hiya.gif]
Hey guys, there is another alternative that not many people are aware of.. I live Colorado and we don't exactly get the best fuel here either. I researched this same subject a few months ago. I came up with a cure and I am very happy with the results. I am running a Zex nitrous kit 125 HP shot with a Diablo 93 tune on pump gas. In fact my timing has been advanced from the stock Diablo 93 tune. Now, your probably saying, how is that possible? Well, I also added an alcohol injection system from snowperformance. The kit which sells for $400 has everything you need to fit your S197 Mustang.
The alcohol can be purchased from Snow or in a pinch you can use the $1 a bottle blue wiper fluid from Wal-Mart along with 2-16 ounce bottles of Heet fuel line de-icer. Also quite a few gas stations are now pumping methanol for the flex fuel vehicles. Any way you look at it, it's easy to get what you need.The system ties into the Masss Air Flow sensor and injects into the intake tube before the throttle body. I use my stock washer fluid bottle as the resevoir it holds approx. 1 1/2 gallons of alcohol and water 50-50 mix. Now, the alcohol effectively raises the octane of your 91 pump gas to about 110 octane.
Also the alcohol reduces the intake manifold air charge temperature about 40-50 degrees. These two benefits that the alcohol injection system make are extremely important. The octane increase allows for more timing advance, the cooling of the intake air charge creates more HP as the air entering the engine carries more oxygen, and that equals more power. So, I carry a couple gallons of the 50-50 mix in my trunk. I top off the washer bottle each time I fill up the tank. The ratio of gasoline to alcohol mix is about 10 gals gas to 1 gal of alcohol.
The system works very well. I also carry my Diablo tuner in the car just in case the system fails, I can load the stock tune back in until I get it fixed. Check out the link above to get more info. There are a ton of guys using this system and they can be used on normally aspirated motors too. They really work best on cars with nitrous, turbos and superchargers. So much so that they even outperform the intercoolers on those applications.
Your combo is pretty similar to mine (except you have an auto and different gears), so maybe Brent hooked you up with a California tune already. If you're not sure, run the RPMs up in a lower gear, going up a hill to put more load on her, and listen carefully to doublecheck.
ORIGINAL: 07GTEddy
autoedit
09-27-2015 06:37 PM
mrappe
09-26-2015 10:16 AM
mungodrums
Suspension
09-24-2015 10:12 PM
