Anyone familiar with these line lock?
ORIGINAL: mdcorny
I see all the burnouts, but what about on the starting line? Do you also use this when you stage?
ORIGINAL: scramblr
Not recommended nor should it be needed. The staging area should be flat enough for the car not too roll. Using the line locks is one more thing you have to deal with while staging the car, especially if you're driving a manual. And then if you forget to disengage...you'd look pretty cool sitting at the lights doing a second burnout.
ORIGINAL: mdcorny
ORIGINAL: moosestang
I rolled backwards at Gainesville and redlighted. I'd use mine to stage if I had a momentary switch on the shifter or steering wheel.
ORIGINAL: scramblr
ORIGINAL: mdcorny
I use mine, the PMP kit, at the line until the first amber on a bracket tree just to be certain I don't roll deep. The trackes here at not flat and I have rolled deep before. I used a on/off switch in the console where the e-brake access panel is and then a momentary on the shift handle That way the shifter switch is only active when I arm the system with the console switch. I do have a diagram showing how to wire them into the off button of the cruise control without messing up the function of the cruise buttons. That makes it as stealth as possible!
ORIGINAL: MusiccityGT
I have it on my computer at work, but here is the readers digest version - run your line locks of an open ground...Power them up all the time with an open ground just like nitrous kits wire up. Then run you grounds to the Tan and white wire located in the bundle under the steering wheel. see pic 1 You will have to remove the panel under the wheel...2 panels and the horn/air bag. MAKE SURE YOU disconnect the battery before starting.
The best place to tap into the wire is about 6 inches down line right above the tilt lever see pic 2 .
Now when you press the OFF button it will close the ground to the solenoids.
PM me to remind me and I will post them when I am at work. I used a B&M handle with a button in the top. Gotta go, but I will post a link later.
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Sep 25, 2015 06:58 PM
