Jacking points
Old Feb 3, 2007 | 12:31 PM
CrazyHorse0217's Avatar
CrazyHorse0217
Default Jacking points
Where are the best jacking points and jack stand points (front and rear). Should you just use the jacking points indicated in the manual if you have a floor jack? I would like to be able to lift the whole front or rear from one spot, and then be able to place the jack stands. The manual states not to use the differential to lift the rear. I would imagine that the rear axle on each side is the obvious jack stand point for the rear, but what about the front?
Old Feb 4, 2007 | 02:26 PM
Buckshot Barry's Avatar
Buckshot Barry
Default RE: Jacking points
I have the same questions. BTT
Old Feb 4, 2007 | 03:00 PM
wingman75's Avatar
wingman75
ORIGINAL: CrazyHorse0217
This is how I raise the rear despite what Ford says. I think they are just covering their butts in case a car slips off the jack. I'm not saying you should do this I'm just saying this is how I do it. Other MF guys do it the same way and haven't had a problem. The red dots are where the jack stands go. The arrow is where the floor jack goes.
This is how I do the front. Never had a problem front or rear... just be careful and definitely use jack stands. I duct taped a rubber sanding disk pad the top of the jack so it doesn't scratch the frame.
Old Feb 4, 2007 | 03:39 PM
hawgman's Avatar
hawgman
I ♥ Acer
Here ya go
[IMG]local://upfiles/13513/48770492581C494AA7B0103A11CB7D7C.gif[/IMG]
Old Jul 16, 2007 | 11:17 AM
kovar's Avatar
kovar
Thank you very much! The pictures are super helpful.
jwog666
Dec 27, 2021 08:09 PM
flash_xx
Oct 16, 2015 07:23 AM
marc954
Sep 29, 2015 03:05 PM
Sep 25, 2015 09:06 AM
