COMP CAMS!!!
Old Feb 8, 2007 | 04:43 AM
  #21
androdz's Avatar
androdz
I ♥ Acer
Default RE: COMP CAMS!!!
How much was the cam install?
Old Feb 8, 2007 | 04:52 AM
  #22
saleen 8902's Avatar
saleen 8902
we charged $1250 labor the customer brought the parts. we had to pull the motor way easy.right out the bottom
Old Feb 8, 2007 | 05:14 AM
  #23
mpn1jgk's Avatar
mpn1jgk
Does anyboby know where I can go in New Jersey, Pennsylvania area to get the Comp III cams installed?
Old Feb 8, 2007 | 12:57 PM
  #24
SAVAGESS's Avatar
SAVAGESS
+1 I like to know as well..
Old Feb 8, 2007 | 01:10 PM
  #25
my77stang's Avatar
my77stang
saleen, isnt it possible to do with the motor in the car? cant you just remove the valve covers and remove them? i would think if you were carefull to line up the cams before removing and kept the chains taught while the cams were out it would be possible (but i havent seen these apart which is why i would like to know)
Old Feb 8, 2007 | 02:08 PM
  #26
saleen 8902
ya but changing the springs and i put ported heads. its way easy to pull the motor and easy to work on. we can pull the motor in 30-40 min
Old Feb 8, 2007 | 08:51 PM
  #27
JimsGT's Avatar
JimsGT
ORIGINAL: mpn1jgk
I'd ask JDM in Toms River, NJ, or Evolution in PA, or Valley Performance in north Jersey (Belleville)
Old Feb 8, 2007 | 09:18 PM
  #28
MusiccityGT's Avatar
MusiccityGT
I did mine in the car.Itis a 10+ hour job with the spring change, the cams themselves are a breeze. We did a set for someone else and charge $1000 labor. My tuning was done with an SCTII by RWTD in Mobile Al. He did an awesome job with the tuning and I have had 0 problems.
Old Feb 8, 2007 | 10:03 PM
  #29
my77stang's Avatar
my77stang
i dont get whats so hard about the spring change? when working in the machine shop we had a tool that you just pressed down on the springs with while the keepers were loosely sitting between the valve stem and the retainer - it pushed the retainer down and the keepers slid into place. we used this on anything OHC cause you cant get a normal spring compressor in there. if this would work, with filling the cylinders with air i would change out the springs on both heads in the vehicle in probably 30 minutes. btw to remove you just use a deepwell socket on top of the retainer and smack it with a hammer, the keepers pop right out.
am i missing something?
Old Feb 8, 2007 | 10:32 PM
  #30
MusiccityGT
Unfortunately you cannot get a straight shot clearance on the springs. They are under around and behind everything. The castings in the head are a clearance issue on getting to them as well.. I have done what you describe and it would be a lot easier if you could do it that way. The ford shop manual actual says to pull the motor for a spring change.
