New shifter buzz?
Old Feb 9, 2007 | 10:22 AM
mltdwn12's Avatar
mltdwn12
Default New shifter buzz?
I put a Roush short throw shifter in my 06 Roush. I like the feel of it now, but there's a slight buzz that comes from the shifter about half way through each gear. Everything is tight underneath. I even took the shifter handle and adapter off to verify that wasn't the source of the hum. I talked to Roush and they said that's just what happens with short throw shifter [sm=dontgetit.gif] Anyone else have this problem? Any other aftermarket shifters that do or don't do this? I'll buy another brand to get rid of the noise!
Craig
Old Feb 9, 2007 | 10:38 AM
stangster06's Avatar
stangster06
I ♥ Acer
Default RE: New shifter buzz?
+1???
Old Feb 9, 2007 | 11:19 AM
WuStangKlan's Avatar
WuStangKlan
I ♥ Acer
Roush in a Roush should be perfect man - keep after them - have them send another shifter - don't accept that answer unless money is not an issue. The feedback from any peoples here that have them can help here!!!
Old Feb 9, 2007 | 03:01 PM
likemike99's Avatar
likemike99
I am not sure if this is the same, but I just installed a tri-ax and get a vibration at about 3.4k rpm and higher. it sounds like the driveshaft is rubbing. I checked the clearance and it is not. You can feel it in the shifter. sorry if it is not the same problem. I am not sure what is up with yours or mine
Old Feb 9, 2007 | 03:04 PM
mltdwn12's Avatar
mltdwn12
That sounds almost exactly like mine. I can feel it as well.
Old Feb 10, 2007 | 12:47 PM
Kaldar142's Avatar
Kaldar142
it does this in other cars too, my 240 had b&M and it had an insane buzzing sound at higher rpms. im pretty sure its normal for a short shifter
Old Nov 9, 2008 | 09:43 PM
1badblue50's Avatar
1badblue50
I have same problem. Cant stand the noise.
Old Nov 9, 2008 | 09:54 PM
Texotic's Avatar
Texotic
haven't heard of this yet. anybody with the MGW get this problem?
Old Nov 9, 2008 | 11:23 PM
deekum1627's Avatar
deekum1627
its normal but if its a rattle then its not
Old Nov 9, 2008 | 11:54 PM
Ato's Avatar
Ato
It's kind of hard to avoid more drive train noise especially when you are replacing mushy rubber w/ more rigid poly or metal bushings.
