bumpsteer problem???
Old Feb 10, 2007 | 11:13 PM
redfiregt2006's Avatar
redfiregt2006
Default bumpsteer problem???
hi guys, i have a mustang gt, 2006 with auto transmission. i had a crash a few months back and the car needed some supension parts to be replaced. i have already re-replaced those parts which were springs and shocks with the steeda sport springs and tokico d-specs. i'm pretty happy with the way it handles now, except that when i go over some bumbs at mid-high speeds, the steering wheel pulls to the side. is this normal, or is something wrong with my suspension?? i read somewhere that this may occur because there is a suspension component that is bent. i was just hoping that it is something easily rapairable. on monday i'm getting camber bolts installed and an alignment. do you think if i finish the suspension with adj. lower control arms, lca relocation brackets and an adj. panhard bar, will this correct my problem???
thanks a lot for everything, i know i'm not a regular poster, but i've learned alot from you guys.
Old Feb 10, 2007 | 11:30 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: bumpsteer problem???
I have similar experiences with mine doing the same over bumps. Actually many do, so I assume it is more of less normal, maybe more pronounce with the lowering of the car.
Old Feb 11, 2007 | 12:01 AM
redfiregt2006
thanks a lot man...lets just hope its curable with the install of lca's and relocation brackets, although i dont know if that would help because those are for the rear, and the problem is up front. anyone else know something about this?
Old Feb 11, 2007 | 12:03 AM
howarmat's Avatar
howarmat
s197 Junkie
Yeah that is not going to help you.
Old Feb 11, 2007 | 12:05 AM
howarmat's Avatar
howarmat
s197 Junkie
http://www.stangmods.com/Steeda-Bump...GT-p/00187.htm
This might solve the problem but I never looked into it as it does not happen often enough to bother me.
Old Feb 11, 2007 | 12:07 AM
ZZLEGEND's Avatar
ZZLEGEND
dont know if this will help
http://cgi.ebay.com/ebaymotors/2005-...spagenameZWDVW
Old Feb 11, 2007 | 12:10 AM
ZZLEGEND's Avatar
ZZLEGEND
another one
http://cgi.ebay.com/ebaymotors/05-06...spagenameZWDVW
Old Feb 11, 2007 | 12:44 AM
redfiregt2006
thanks a lot man, that would probably help. do you know if it fits without those X2 ball joints? i dont know what those are, but it says that the bumpsteer kit is recommended if you have those. is it an easy to install part like a direct replacement? has anybody installed it?
Old Feb 11, 2007 | 12:56 AM
ZZLEGEND's Avatar
ZZLEGEND
hey redfire. i dont know much about them but i have seen them on ebay by different sellers. you might want to check ebay and i would guess some other people on here will give you some help and more info. there is a lot of good things about this forum. i am also fairly new here and have learned alot. good luck to ya what ever you do. im sure you will get it figured out. just keep checking this thread.
Old Feb 11, 2007 | 12:58 AM
ZZLEGEND's Avatar
ZZLEGEND
also mine is stock and not lowered yet. but who knows???? maybe later i will do it also.
