bumpsteer problem???
Old Feb 11, 2007 | 01:05 AM
redfiregt2006's Avatar
redfiregt2006
Default RE: bumpsteer problem???
but you are not experiencing my problem, are you? you can drive through all kind of bumps and your car feels planted i suppose? you steering wheel doesnt move right?
(waits for crazy al to come in and teach us something new)
Old Feb 11, 2007 | 11:21 AM
ZZLEGEND's Avatar
ZZLEGEND
thats correct redfire. mine does not pull to the right when hitting a bump. it stays straight and true. i have heard that they do have a little bump steer when you lower them. but there has to be a fix. like you said, where is crazy al? here is an old thread about lowering but i dont know if they talk about bump steer. but you could ask some other people. also do some searching on other past threads and you might come up with something. also how much did you lower yours? front and rear? i might be doing it down the road but dont want to drop to much. an 1" or so all around would suit me. maybe 1.2 in front and 1.4 in the
back.https://mustangforums.com/m_451192/tm.htm
Old Feb 11, 2007 | 01:01 PM
Kaldar142's Avatar
Kaldar142
you need to adjust your suspension components to adjust bumpsteer, like on my 240 (IRS) i got adjustable tie rods to help adjust bumpsteer, along with adjustable rear upper control arms
Old Feb 11, 2007 | 07:44 PM
dkegel's Avatar
dkegel
Have you had the alignment checked recently? If the toe is off, that will cause bumpsteer. I'd check that.
Dave Kegel
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 16, 2015 07:53 PM
Sep 1, 2015 08:16 PM
