My Very Own OIL COMPARISION CHART
OK, After reading 18 zillion different threads about oil changes the discussions on which oil is best I thought it would be good to give a little side by side comparison. This way everyone can see for themselves which is "best" and make their decisions based off of fact instead of opinion.
RE: My Very Own OIL COMPARISION CHART
ORIGINAL: my77stang
Here is a link to some RP oil tests that are interesting.
http://www.royalpurple.com/video/video.html
I often find that alot of research whether clinical or provided by a manufacter is often skewed or intenionally designed to yield a result/outcome.
The big question is are those values in those charts within normal limits for operating safely and are the differences significant? (i.e does one oil become sludge at -200 C and the other -250 C, but who cares since we won't ever approach those temps?)
The oil companies and the car dealerships/lube places are more concernced about 3000 mile intervals than Ford is. If Ford had engines that were known to fail at 80k miles and a lack of regular 3000 mile oil changes people wouldn't buy Ford. Ford'ds incentive is to build an engine that doesn't need oil changes for long extended periods of time and an engine that lasts as long as possible.
A car manufacter's goal is to keep you away from the service department as long as possible so that you associate value to the car and buy another one.
Thanks for these posts. I findthe first chart quite informative.
However, I would beware that second one regarding the oil filters. I posted the link to that full site the other day. If anyone wants it again, here it is again:
http://home.mindspring.com/~cewhite3nc/index.html
....However, that "rating system" is EXTREMELY subjective. The only part of it that is actually calculated is the filter surface area information and of course the price. But the vast majority of the "data" which goes into the final results is basically just one man's opinion.
i know the first chart is very technical, and is beyond me in many respects but its the hard scientific proof of how an oil performs.
my take is this.....
quaker state and royal purple dont meet the "SM" specs, which is the latest that modern oils should conform to (like the ford syn blend
royal purple also fails to meet the "GF-4" specs - another example of this oil not meeting the latest specs.
if im reading these right, low viscosity is good which means if you live at the south pole mobile 1 is best but at normal cooler temps pennzoil is best for initial startup
redline is the least volatile when it comes to high heat
i believe sulfer is a bad thing, so of those listing this spec valvoline is best.
i applaud pennzoil and valvoline for providing the most comprehensive details on their product - it tells me they have nothing to "hide"
overall, my take is that it appears redline really is the best oil followed by a tie between mobile 1 and amsoil. it also seems like royal purple falls short in multiple areas which is enough for me to not wanna use it.
that being said i don't think mobil 1, pennzoil, valvoline, motorcraft, or amsoil would ever cause us a problem. these numbers ARE close enough, and since i have been using pennzoil in every other vehicle i own and in the new stang since its first change i will keep the oil in there the same.
btw, i appreciate the appreciation of me spending half my morning doing this research.... hopefully it serves the community well
