installing louvers
Old Feb 13, 2007 | 03:24 PM
kingsmate20's Avatar
kingsmate20
Default installing louvers
Anyone have advice on and easy way to install them? I have the 3m tape, and they fit perfectly, but once I try and put them on it always seems like I stick em in the wrong space, and then when I have to pull them back up to adjust the tape looses it's stickiness. It's pretty frustrating.
Old Feb 13, 2007 | 04:13 PM
redfireshaker06's Avatar
redfireshaker06
Default RE: installing louvers
Your suppose to only pull a little bit of the tape cover off of each peice. Let it hang out and put the louver on, then when you get it where you want. Pull the covering off through the side of it, 1 piece at a time
Old Feb 13, 2007 | 04:35 PM
suoperdave84's Avatar
suoperdave84
Here's a link to an install sheet from CDC. Fairly universal install no matter what brand you use. One tip is to place the scoop/louver on the car and use masking tape to mark the edges. Then you'll know exactly where to stick it.
Here's the CDC link:
http://www.classicdesignconcepts.com...coops%20TS.pdf
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
