Lowering just the rear
RE: Lowering just the rear
Yep, the Roush springs work well.
You don't need an alignment becasue you are not changing your camber or toe. However, you will need the adjustable panhard bar to re-center your rear end and adjustable LCAs to fix your pinion angle.
ORIGINAL: cbondlv
I think i want to do the same thing, just lower the rears. i wonder if anyone have pics with just rear springs lowered.
ORIGINAL: cbondlv
thx. So will are handling still be bad since its still pretty much stock.
Roush, Steeda Ultralite, or Eibach Pro-Kit springs: $200
camber bolts $30
BMR or Spohn adjustable LCAs $220
BMR or Steeda rear sway bar kit $200
BMR or Spohn adjustable panhard bar $130
BMR panhard bar support. $100
Toicko D-spec shocks $540
Rears only. (measure rear alignment before you swap, then after. If you are within 1/8" to 1/4" L-R, you won't need to buy adj panhard bar. I did, most folks do. JMO, you are wise to leave front alone.
[IMG]local://upfiles/24316/825954741E9A46D28BCA951F18AAE71C.jpg[/IMG]
[IMG]local://upfiles/24316/1B281DBC7AB74FA3A21F50C2511BC293.jpg[/IMG]
One year later/10k after riding with just the roush rear springs no problems to report.
Just got around to getting a panhard bar. Came today as a matter of fact. And ordering adj. LCA
anyday now.
Im just knocking off stuff off the mods list right now, starting with the less expensive ones, and ones I can handle myself. Just wish I had more mad money!
CrazyAl does give some darn good info. You can't go wrong listning to his advice.
Tip: Do one side at a time. Very easy mod
[IMG]local://upfiles/17179/2AB5CFD046D0462C95776DCF052274CE.jpg[/IMG]
[IMG]local://upfiles/17179/52A2AF33985844D488BADDC08193C13C.jpg[/IMG]
anyday now.
