Forged Bottom End Question
Old Feb 22, 2007 | 04:26 PM
GrabberOrange07's Avatar
GrabberOrange07
Default Forged Bottom End Question
I have read many posts about the need to add forged lower end components when pushing more than 475 RWHP with a supercharger. I dont however read about what parts are suggested, cost, etc. Can someone chime in?? Do you need new pistons or are just the rods the weak link? How about the crank?? I read the block is good for as much as 800 HP which is way more than I would ever need for a street car.
Old Feb 22, 2007 | 06:14 PM
RodeoFlyer's Avatar
RodeoFlyer
Default RE: Forged Bottom End Question
rotating assembly - pistons, rods, crank
Old Feb 22, 2007 | 06:15 PM
CrazyAl's Avatar
CrazyAl
The rods are the weakest link. However, it makes little sense to go through all the effort and expense of tearing down the engine to just replace the rods. Typically the pistons, rods, and crankshaft are replaced.
Look for a "rotating assembly kit" which includes the above parts plus the incidentals like piston rings & pins, etc. Check vendors like Livernois, JDM, Sean Hyland, and Modular Mustang Racing for various options. You will then need to pay for the labor to have the parts installed.
Old Feb 22, 2007 | 06:59 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
rods go first, then pistons, then crank. but if your replacing one, its kind of dumb to not replace everything.
Old Feb 22, 2007 | 09:31 PM
|UCF|chron's Avatar
|UCF|chron
plus install on these thing must not be cheap
Old Feb 22, 2007 | 10:06 PM
2oo5stang's Avatar
2oo5stang
if you know how to tear it down and rebuild it back, that's what i would do, alot cheaper if you do it. and it's not hard.
Old Feb 22, 2007 | 10:13 PM
my77stang's Avatar
my77stang
anyone know what kind of pistons these things have? are they cast or forged? im guessing from the factory these motors have hyperutectic (sp?) but i dunno
Old Feb 22, 2007 | 10:24 PM
CaptRestless's Avatar
CaptRestless
From what I've learned...
The pistons are hyperteunetic (sp?) and the rods are powder coated.... something.
Although the V6 apparently has forged rods which doesn't make sense to me....
Old Feb 22, 2007 | 10:37 PM
CrazyAl's Avatar
CrazyAl
Stock pistons are cast Hypereutectic, they're actually not that bad. The rods are powdered metal.
Old Feb 22, 2007 | 10:58 PM
svt93style's Avatar
svt93style
I understand the stock pistons leave much to be desired.
The rings are really high up on the piston for emissions reasons..
To up grade your bottom end your looking at rebuilding the motor.
Or you can always get something from D.S.S. Racing.
Not only is it pricy either way but then on top of that
the labor is what kills you...unless you do that yourself
I did it on my foxbody but I had an other car..
it takes a bit of time to get it "all" done.
