Please help diagnose problem
Old Feb 25, 2007 | 05:10 PM
billyclo's Avatar
billyclo
Default Please help diagnose problem
Ok, my car has been sitting for a couple days in relatively cold weather (It's been in worse.) I parked it the other day, and turned the wheels all the way to the left. Anyways, I get in it today and the brake pedal will not move. The steering wheel will not move, and when I put the key in the ignition...it won't move either...it stays locked. What could this be? The key fob unlocks the car..... My thought just now was that perhaps the chip in the key went bad?
What could it be? Would it be something covered by Ford? Thanks
Old Feb 25, 2007 | 05:23 PM
shaners90lxhatch's Avatar
shaners90lxhatch
Default RE: Please help diagnose problem
I have no idea what the deal is with the brakes. There shouldn't be anything holding them back. Otherwise, your steering wheel lock may be sticking. Wiggle the wheel left and right with a little force as you try to turn the key. This is typically something that happens on older vehicle's but I guess it could be temperature related. Again, to my understanding there is nothing related to the lock cylinder or the steering wheel will affect your brake pedal.They may just be pumped up, I wouldn't worry about the brakes until after you start the engine.
Old Feb 25, 2007 | 05:36 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
ORIGINAL: shaners90lxhatch
+1
Old Feb 25, 2007 | 05:39 PM
howarmat's Avatar
howarmat
s197 Junkie
+2
Old Feb 25, 2007 | 06:06 PM
Jays Mustang's Avatar
Jays Mustang
Ya sounds like you just have to turn the wheel. It happens to mine too. I don't know about the brake peddle. If it was a key code it would turn but not start the car.
Old Feb 25, 2007 | 06:12 PM
MartyMoose's Avatar
MartyMoose
+3
Old Feb 25, 2007 | 07:22 PM
mekanek's Avatar
mekanek
if your wheels are turned to the right,pull the steering wheel to the right to relieve the pressure offof the linkage to the lock .the key should turn easily
bjdutch2005
Mar 24, 2017 03:38 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
jessicarabbit
Sep 25, 2015 12:41 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
