Speedometer is off
Old Feb 25, 2007 | 10:33 PM
jonpo's Avatar
jonpo
Default Speedometer is off
OK so I have a 06 Mustang GT, 5 speed (3.55 final drive) and 18" premium wheels from the factory. Everything's stock. Anyway, I'm driving by one of those signs that shows your speed, and I decided to test it out to see if my speedometer's accurate. So, I set my cruise on 40, but the sign says I'm only going 37. I then reset my average speed on my trip computer and it registers 37 too. I'm glad it registers fast instead of slow(for cops and stuff), but it still bothers me. Anyone else noticed this or am I just crazy?
Old Feb 25, 2007 | 10:39 PM
ohsixgt1217's Avatar
ohsixgt1217
Default RE: Speedometer is off
Quite possible its not just you. Lol id be happy considering it reads fast lol. But maybe your computee wasnt set for the 18's you have? idk possibly tho. Nothing a tune cant adjust. Personally i wouldnt worry about it, unless you are getting a tuner then id adress it
Old Feb 25, 2007 | 10:42 PM
hawgman's Avatar
hawgman
I ♥ Acer
Well, your speedo is electronic. Your trip computer ( including average speed reading ) is electronic. They both read from the PCM. So it is going to be a little difficult to compare the reading from the average speed setting in the trip computer to what the needle indicates on the speedometer since they both are controlled by the same source. As for the side of the road radar sign, it could possibly be off my a MPH or two also simply because since it is not used by law enforcement to hand out tickets it doesn't have to be calibrated at regular intervals.
If you truly think it is off by 3 MPH, take it to Ford and have them check it. Or you could also take it to a dyno shop and do a pull and compare the MPH on the dyno to what your speedo says. The dyno is going to give you an accurate speed reading.
Old Feb 25, 2007 | 10:59 PM
howarmat's Avatar
howarmat
s197 Junkie
+1 to the dyno idea but I am guessing that it is not actually off because those signs are not accurate.
Old Feb 25, 2007 | 11:07 PM
jonpo's Avatar
jonpo
Well I did notice that when I'm at a dead stop, my speedo registers 2-3 mph. So maybe the dial is just a little bit off. If that's so, can it be fixed?
articman
Jun 21, 2018 11:45 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Nurdyguy
Aug 21, 2015 10:23 PM
danclint
Nov 28, 2004 10:32 PM
Leadfoot
Sep 10, 2004 03:05 PM
