ZEX - Opinions from personal exp. please
#21
RE: ZEX - Opinions from personal exp. please
Depends I have missed a gear and nothing happened since I let of within milisecs, sometimes that is it for your engine, the reason for this is while your engine does a cutoff because it hits the rev limiter, the nitrous is spraying nitrous and fuel inside the chambers which in turn ignite and over rev the engine. Usually when you are on nitrous u try to shift slower almost like double checking.
Andrew
Andrew
#22
if your speed shifting then the nitrous will be on all the time. The zex works off thetps so unless your full throttle when your shifting, it will spray if you let off the gas a little you should be ok.
#24
Okay so what else do I need, I have the bottle warmer, purge, and cupholder with activator switches. I'm trying to order a window switch and the fuel cutoff then what?
-Jeff
-Jeff
#25
ORIGINAL: nothsa
-Jeff
-Jeff
#27
WellI put the 75 on and well It looks like a 75 is not enough. mind you though, I didnt have a bottle heater on it andI know psi could have probably been at like 600 vs 900 which they reccomend. but it was still a nice little pull.
#28
probinator, could I please convince you to take some detailed pictures. I can not figure out how to wire the stupid electrical part, I think the guy I bought it off of on ebay cut all the wires short and I may need to rewire... How did you mount your bottle in the trunk so it wouldn't move?
Thanks!
Jeff
Thanks!
Jeff
#29
I had my buddy make some metalplates to attach to the board thing in the trunk.Otherwise you would have to drill into your car. and we couldnt find room so he just made me plates.
as far as electrical goes, what do you mean to short? you should have a wire for power, ground , and the tps? Extend them if you need to, just make sure you make the connections good. i would solder them if you can. For the activations switch we tapped in to the ciggerette lighter in the arm rest. and I put my switch next to my shifter on the passenger side.
Ill try to take pics when I can.
#30
The one from the main ZEX NCU the red white and black wires. The red one isn't very long, isn't it supposed to go all the way into the cockpit to the arming switch?Is this just normal wire that I could pick up anywhere?
-Jeff
-Jeff
