Sponsored by:
Sponsored by:
06's and 07's faster?
Old 03-02-2007, 11:37 AM
Juntech
Juntech's Avatar
Default 06's and 07's faster?
Why do some of you guys say the 07's are slower than 06's? Is it because of the extra structural support from the GT500? The latest Road and Track estimates the GT's weight as 3600 lbs. Where the 05-06's were around 3400 lbs.
Anyone shed any light?
Juntech is offline
Old 03-02-2007, 11:53 AM
GT Newbie
GT Newbie's Avatar
Default RE: 06's and 07's faster?
I believe the 05's & 06's were something like 3485, which makes the 07 only about 87 lbs. heavier (see 2k05GT's posting below with specs from Car & Driver!).
Not only has it been structurally improved however, but the steering was improved as well.
Not a bad trade-off at all if you ask me for only a lousy 1 / 10 of a second difference (5.0 as opposed to 5.1 for 0 - 60)...!
If every 07 owner and his wife or g / f goes on a diet, that should take care of the weight difference right there...
GT Newbie is offline
Old 03-02-2007, 11:57 AM
timothyrw
timothyrw's Avatar
or divorce the wife/breakup with the girlfriend!
"i'm sorry honey, but you're literally holding me back!"
ORIGINAL: GT Newbie
I believe the 05's & 06's were something like 3485, which makes the 07 only about 115 lbs. heavier.
Not a bad trade-off at all if you ask me.
timothyrw is offline
Old 03-02-2007, 12:17 PM
Stig
Stig's Avatar
For the manual's at least, the reason they feel slower is that the diff ratio is 3:31 for improved gas mileage,which is why the 3:55 is a popular option.
Stig is offline
Old 03-02-2007, 12:53 PM
dborne
dborne's Avatar
on the 07 the 3.55's is a $100 option (manual only)
dborne is offline
Old 03-02-2007, 04:11 PM
Juntech
Juntech's Avatar
THis is good news, now if they can fix that leak...
Juntech is offline
Old 03-02-2007, 04:20 PM
VerginaStang
VerginaStang's Avatar
My 06 is faster stock than most other stock 06's bc its black.
VerginaStang is offline
Old 03-02-2007, 04:33 PM
Daniel60
Daniel60's Avatar
I highly doubt there is any difference.
Daniel60 is offline
Old 03-02-2007, 04:40 PM
2k05gt
2k05gt's Avatar
[ul]SPECS FROM CAR and DRIVER REVIEWS......
2005 FORD MUSTANG GT--V8 (4.6 Liter) Specs
ENGINE TYPE: SOHC 24-valve V-8, aluminum block and heads, port fuel injection
Displacement: 281 cu in, 4601cc
Power (SAE net): 300 bhp @ 5750 rpm
Torque (SAE net): 320 lb-ft @ 4500 rpm
DIMENSIONS:
Wheelbase: 107.1 in
Length: 188.0 in
Width: 73.9 in
Height: 55.4 in
Curb weight 3483-3518 lb
EPA city/hwy mpg 17-18/23-25
Fuel-tank capacity/range 16.0 gal/272-288 mi
TRANSMISSION: 5-speed manual
Gear Ratio 3.55:1
SUSPENSION
F ind, struts, coil springs, anti-roll bar
R rigid axle, coil springs, anti-roll bar
BRAKES
ABS standard
12.4-inch ventilated front brake discs
11.8-inch rear brake discs
C/D TEST RESULTS:
Zero to 60 mph: 5.0 sec
Zero to 100 mph: 13.0 sec
Zero to 130 mph: 25.5 sec
Street start, 5-60 mph: 5.6 sec
Standing ¼-mile: 13.5 sec @ 104 mph
Top speed (drag limited): 149 mph
Braking, 70-0 mph: 169 ft
Roadholding, 300-ft-dia skidpad: 0.90 g
2006 FORD MUSTANG GT--V8 (4.6 Liter) Specs
DIMENSIONS:
Wheelbase: 107.1 in
Length: 188.0 in
Width: 73.9 in
Height: 55.4 in
Curb weight 3488-3525 lb
EPA city/hwy mpg 17/23-25
Fuel-tank capacity/range 16.0 gal/272 mi
Gear Ratio 3.55:1
SUSPENSION
BRAKES
ABS standard
C/D TEST RESULTS:
Standing ¼-mile: 13.6 sec @ 103 mph
Braking, 70-0 mph: 170 ft
2007 FORD MUSTANG GT--V8 (4.6 Liter) Specs
DIMENSIONS:
Wheelbase: 107.1 in
Length: 188.0 in
Width: 73.9 in
Height: 55.4 in
Curb weight 3575 lb
Gear Ratio 3.31:1
SUSPENSION
BRAKES
ABS standard
C/D TEST RESULTS:
Zero to 60 mph: 5.1 sec
Zero to 130 mph: 25.6 sec
Standing ¼-mile: 13.8 sec @ 103 mph
Top speed (drag limited): 147 mph
Roadholding, 300-ft-dia skidpad: 0.89 g[/ul]
2k05gt is offline
Old 03-02-2007, 05:19 PM
dborne
dborne's Avatar
the stats on the 07 times would be a little different with the 3.55's i would imagine
dborne is offline
Quick Reply: 06's and 07's faster?
