Exhaust Vibration
ORIGINAL: redfireshaker06
Please do, but if I know what your saying, mine is not having that problem. If I remember correctly, the hanger is not all the way. But your having the same exact symptoms I am to the T. I'm glad though finally someone found a fix and hopefully mine will get fixed. But there is a plate your saying thats underneath the car thats vibrating? I'll check when I get home tomorrow from work. Its to late now
Check to make sure the tips of the hangers aren't hitting anything (like bolt heads).
Check all the bolts to make sure they're tight.
Go over the entire length of the exhaust system, headers to axle-backs, to check clearance.
Try hitting both sides of the mid-pipe with your hand and listen for anything clanging, tapping, or vibrating.
The TSB (if i'm not mistaken) is for the gromet peice that's attached to the crossmember. They can become loose and rattle or vibrate. 05ROUSHER, correct me if i'm wrong.
well, I'm having the samething and I saw the TSB using the 3" hose clamps for the 2 rubber gromits. I went and bought my own and I will try it this weekend. I figured if this was FORD's fix for the problem that I could do that in the drive way instead of having to take it in for something like that. I'm not sure how these 2 clamps will fix the problem but people who have had it done said it fixed their vibration. So I figured for 85 cents a piece I figure what the hell I'll give it a try.
george
george
That looks like its my problem. how the heck did you bend those hangers. I tried to beat the Shiat out of it with a hammer. It might have moved2/16's if thator so. I shoved a piece of thick material in there. If it doesn't melt that should help it. I haven't had a chance to take it out yet. But I can tell right off in the morning when I brake. I always hear it when I go to work. Thanks man for the help. I sure hope I moved the hanger enough.
ORIGINAL: TheDarkPath
Well, the crossmember that the gromets are attached to was relaying the vibration into the interior of the car.
http://www.2005stang.com/gallery/alb...%20console.pdf
Just an FYI...i banged the **** out of the crossmember and I had no rattles....still have a rattle at 3k under load though [:@]
Sep 30, 2015 12:39 PM
Sep 24, 2015 09:18 PM
