set my mind at ease please..
Old Mar 8, 2007 | 10:35 PM
CLUBSFIT's Avatar
CLUBSFIT
Default set my mind at ease please..
Just got done installing lca's,panhard,tri-ax, and aluminum driveshaft today This only one week after installing my 4:10's. So fast and responsive!! HOWEVER, I need you to put my mind at ease.. The driveshaft makes a drone like sound under load.[] Is this normal?? and I know not the gears, because no issue until driveshaft. This is not a whine, but almost like exhaust drone..I have the pinion angle set at -2.5 degrees.
thanks in advance!!
Old Mar 8, 2007 | 10:52 PM
The Ghost's Avatar
The Ghost
Default RE: set my mind at ease please..
Don't be so sure it's not the gear. You don't have all that wonderfull factory vibration/noise reduction that was built in to the two piece shaft. The thing has an isoelastomer bushing at the break. This equals NO NOISE. I also run an Aluminium drive shaft, solid LCA's,LCA brackets,adjustable upper, adjustable panhard, with FRPP lowering springs. No gear change yet.I am smooth as silk. Try this, and it's free if you set the pinion angle yourself. I did not just set mine to -2.5d, I measured the angle at the tranny output and matched it exactly. I can not give you a number because it has been over a year now andI simply don't remember. But I am sure it WAS NOT a perfect -2.5d. Try this and see. I drag race at the track a lot so I can offer real input into sound and vibes under load.
Old Mar 8, 2007 | 10:57 PM
CLUBSFIT's Avatar
CLUBSFIT
ok thanks, I dont feel vibration (other than normal), just definate howl type noise under load, especially on freeway. I am hoping it is from the one piece design plus the large hollow driveshaft. If it is not normal, is it usually too little or too much angle?? am I better close to parallel, or am I better w/a little more angle??
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
mustangheaven
Oct 7, 2015 10:23 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
