Ford Warranty
Ford Warranty
I have a 2006 V6 Mustang and I need to know what performance modifications will void my warranty? I want to add JBA dual exhaust, JBA shorty headers, CAI, and a tuner but I don't want my warranty to be useless because I am a college student and I don't want to have to worry about the expenses of a car that is broken down (if it ever happens). Thanks.
RE: Ford Warranty
ORIGINAL: Kwiatkowski18
EDIT: I don't mean to sound rude but I see this same question asked repeatedly. Have you tried a search on the subject?
RE: Ford Warranty
ORIGINAL: 555*
Nothing voids warranties, unless what you installed can be traced back to the malfunction. Say your motor catches on fire. they can't blame your CAI.
Better off keeping a car stock or as close to stock as possible if you value the manufacturers warranty. Warranty cost is a huge problem for the OEM's and reducing that cost is priority #1. The OEM's don't care about your need to have a faster or lower car. They spend billions on R&D to make sure the car they sell will last through the warranty period. You messing with that equation through modification gets very little tolerancefrom the OEM's.
RE: Ford Warranty
ORIGINAL: bascho
Of course 'they' can. They haveteams of lawyers on the payroll....do you? Sure, you might win in court.....but it will cost you money and time.
ORIGINAL: 555*
It all depends on the dealership too. Again the warranty isn't voided by being modded.
RE: Ford Warranty
ORIGINAL: 555*
ORIGINAL: bascho
ORIGINAL: 555*
How about a suspension mod. Are you going to be able to prove that lowering springs didn't impair the vehicle's suspension, steering or braking characteristics? Because I'm sure Ford can make a pretty valid arguement that they could have impaired those systems.
Now, a CAI or lowering springs are most likely not going to void the warranty coverage on a body wiring harness repair or paint defect. But making statements like modding won't void a warranty is far to broad in scopeto be true.
RE: Ford Warranty
ORIGINAL: bascho
Do you approve warranty claims for Ford Motor Company? If not, then you shouldn't make statements about things you know nothing about. Can you mod a vehicle without it affecting the warranty.....sure. Can you say with 100% certainty that Ford is going honor your warranty when you've modded the vehicle. I say No. Why, because even though the CAI may not have caused the engine failure......how are you going to prove that? An engine is a highly technical mechanism......Ford can easily defend that the CAI could have cause the engine failure.
ORIGINAL: 555*
ORIGINAL: bascho
ORIGINAL: 555*
Might want to check this out bud:
https://mustangforums.com/m_1524512/tm.htm
Andagain modsDO NOTvoid your warranty.
