Hood Shake at high speeds? (Don't have time to search)
Old Mar 16, 2007 | 10:24 AM
redfireshaker06's Avatar
redfireshaker06
Default Hood Shake at high speeds? (Don't have time to search)
I am at work and just about out of time for break. What brand hoods pins can virtually eliminate the hood shake at high speeds? Thanks in advance
Old Mar 16, 2007 | 12:34 PM
PullMeOverRed05's Avatar
PullMeOverRed05
Default RE: Hood Shaker? (Don't have time to search)
I got my Ford Racing pins from Summit
Old Mar 16, 2007 | 01:18 PM
howarmat's Avatar
howarmat
s197 Junkie
I have read the the hood pins will not take care of the hood shake that ours cars have. They are more for appearance.
Old Mar 16, 2007 | 01:23 PM
40thgtfl's Avatar
40thgtfl
you read wrong.
Old Mar 16, 2007 | 01:25 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
I'm installing Sparco pins. Not for looks but because I have had friends that had bad experienced with fiberglass and carbon hoods.
Old Mar 16, 2007 | 01:43 PM
LGNDLIME05GT's Avatar
LGNDLIME05GT
I have the shaker hood cut into my original hood. You shouldnt have any shaking if its a shaker with original hood. If its a aftermarket fiberglass hood then there is nothing that can be done about the shaking.
If your talking about the shaker unit moving. It is attached to the engine. Its going to move.
Old Mar 16, 2007 | 01:49 PM
redfireshaker06
No sorry, Its a typo. I experienced my first bad hood shake the other day. I want to get it fixed. I'm not really a fan of the sparcos they look kinda funny. I know the shaker scoop is suppose to shake. So nothing will fix the hood shake or just put up with it?
Old Mar 16, 2007 | 02:05 PM
howarmat's Avatar
howarmat
s197 Junkie
I went back and read several threads. You may just adjust the stops and that could fix it. Other have taken it to the dealer and had them look into it and do the adjustments.
Old Mar 16, 2007 | 02:34 PM
wthalliii's Avatar
wthalliii
Default RE: Hood Shake at high speeds? (Don't have time to search)
How fast are you guys going when you get hood shake? I've only had my GT up to 100, but I haven't seen any hood shake. Could be a vision problem on my part, I guess. I am old...
Old Mar 16, 2007 | 02:47 PM
Rock36's Avatar
Rock36
I get it at as low as 80 mph. I am really tired of it. I've adjusted my hood stops but it makes no difference on mine.
