Tire question.
Old Mar 16, 2007 | 08:04 PM
LoLO's Avatar
LoLO
Default Tire question.
I wanna change my tires but I want to keep my wheel. I got a mustang GT with the 17 inches wheels so my pirelli are 235/55-17 like everybody knows.
My question is, can I change these tires for some Nitto 555 that are wider ( 255/50/17 ) ?
and if yes, how wide can I go with the stock rims ?
Thanks
Old Mar 16, 2007 | 08:09 PM
Drivesthebeast's Avatar
Drivesthebeast
Default RE: Tire question.
Why would you wanna do that? You'll have sidewalls that taper IN to the rims (bow out), and the car won't steer or respond worth a damn...
Old Mar 16, 2007 | 08:33 PM
LoLO's Avatar
LoLO
what if I change only the rear ? so what should I do ? get new rims ? I've heard of people keeping the factory wheels and changing only the tires..
Old Mar 16, 2007 | 09:02 PM
callahan's Avatar
callahan
255/50/17 is the largest tire with the same rolling diameter as the stock tire that will safely fit the stock 17 X 8 wheel. They look and work just fine. They do look better on my aftermarket 17 X 9 wheel, though.
Old Mar 16, 2007 | 09:10 PM
LoLO's Avatar
LoLO
Thank you so much
Old Mar 18, 2007 | 12:34 AM
Plaidpony's Avatar
Plaidpony
Does the 255/50-R17 tire on a stock 17 wheel pose any rubbing issues on a lowered car? Say an 1.5 - 1.75" drop.
Old Mar 18, 2007 | 12:38 AM
Black3vGT's Avatar
Black3vGT
ORIGINAL: Plaidpony
I'm lowered with the stock 17s and have no issues with rubbing.
Old Mar 18, 2007 | 12:46 AM
Plaidpony's Avatar
Plaidpony
Thanks. Wasn't sure if the slightly wider tire made any difference on a lowered car.
Old Mar 18, 2007 | 01:53 AM
05Stang4Me's Avatar
05Stang4Me
The 255 should go on without issue, but it will change your speed O just a bit. You are changing the height; the width doesn't change anything. Maybe look for 255/55/17 and your speed O will remain true. you can punch in the numbers on this site and calculate how far it is going to be off. http://www.1010tires.com/TireSizeCalculator.aspIt probably will be a very small difference. I have been looking into this same issue, because I would like to put a little more rubber on the ground as well. Good luck.
Old Mar 18, 2007 | 03:25 AM
LoLO's Avatar
LoLO
Thanks. Can it be corrected with a SCT calibrator ?
