The Saleen install has begun...
well my install has begun. I advised the installer of the optional parts to install instead of etc. Like the the smaller pulley, the new cold plugs, the injectors, 90mm MAF, (also advised him that to try to use the c+l street intake with the 90 mm maf....if there are any clearance issues he is going to use the inlet hose off my stock air box if I need to order the new extreme instead..some ahve used the c+l street intake tube with a new 90mm maf on the end with a transition silicone hose as I am trying to work without any clearance issues, but i read some cars are different etc...if it does not fit, looks like stock intake tube, then the saleen extreme inlet tube on overnight express for friday, we will see....overall with guages and all it will cost me about $800...so I figure with all of my upgrades and purchases along with the Saleen I am in it for about $5800 installed...including 2 tunes from JDM and the dyno pull on friday...he told me probably will be done Thursday evening or Friday early am at the latest....
RE: The Saleen install has begun...
ORIGINAL: Hufenstang
nice! let me know if you end up having clearance issues because im about to do the same thing you are trying! and definately put up some pictures when its done~
You know guys, the Street does look pretty cool but the Saleen tube does fit nicely and JDM has 'em for a pretty damn good price. Just something to chew on if the Street doesn't fit. Oh, may be a flow issue too? Jim Jr. recommended I use the Saleen tube when I informed them that I already had thee Street.
Oh, I wanted to ask, what gauges did you go with?
