T/B Option perhaps.
Found this the other day and just wanted to know what you guys think. Its sounds like a modified GT500 TB and spacer that will fit 05+ GTs. Im considering this seeing as the TB's out right now are a hit or miss.
http://www.modularfords.com/forums/2...kit-78187.html
http://www.teamjdm.com/index.html The company's homepage thats making the modification.
I've seen this one too. Personally I am not holding my breath.
It may be that they have solved the code-throwing or limp mode issues with some of the aftermarket TBs...but it still doesn't change the fact that larger TBs DO NOT make more HP unless you have a specific need for more airflow. If you have a car with heads or cams on it then this would be worthwhile. But on a stock or lightly modded engine? You'd be lucky to see 1 HP.
jwog666
Dec 27, 2021 08:09 PM
