Saleen PJ Specs?
Thanks Ric! I wonder if the stroker kit alone bumped up the compression, or if they did something else. Anyway, Bruce! Do you plan on adding any mods? CAI? Tune? I'm sure even with your 400 bhp there is still room for improvement. Also, are you going to take it to the track, just to see what kinda times you can get?
All I ever have seen written is High Compression. I will contact Saleen to see if I can get the answer. Better yet here you go:
2007 Saleen/Parnelli Jones Limited Edition Mustang
[/b]
POWERTRAIN/CHASSIS
DRIVETRAIN LAYOUT
Front engine, RWD
ENGINE TYPE
V-8 iron block/alum heads
VALVETRAIN
SOHC 3 valves/cyl
DISPLACEMENT
301.6 cu in/4942 cc
COMPRESSION RATIO
10.5:1
POWER (SAE NET)
400 hp @ 6000 rpm
TORQUE (SAE NET)
390 lb-ft @ 4000 rpm
REDLINE
6500 rpm
WEIGHT TO POWER
9.0 lb/hp
TRANSMISSION
5-speed manual
AXLE/FINAL-DRIVE RATIOS
3.73:1/2.54:1
SUSPENSION, FRONT; REAR
Struts, coil springs, anti-roll bar; live axle, coil springs, anti-roll bar
STEERING RATIO
15.7:1
TURNS LOCK-TO-LOCK
2.8
BRAKES, F;R
14.0-in slotted and vented disc; 11.8-in vented disc, ABS
WHEELS, F;R
19 x 9.0; 19 x 10.0, cast aluminum
TIRES, F;R
275/35ZR19 100Y; 285/40ZR19 105Y, Pirelli PZero Rosso
DIMENSIONS
WHEELBASE
107.1 in
TRACK, F/R
62.8/63.9 in
LENGTH x WIDTH x HEIGHT
189.1 x 74.0 x 56.0 in
TURNING CIRCLE
33.4 ft
CURB WEIGHT
3602 lb
WEIGHT DISTRIBUTION, F/R
53/47%
SEATING CAPACITY
HEADROOM
38.6/34.7 in
LEGROOM
42.7/30.3 in
SHOULDER
55.4/53.4 in
CARGO VOLUME
13.1 cu ft
TEST DATA
ACCELERATION TO MPH
0-30
1.8 sec
0-40
2.7
0-50
3.7
0-60
4.7
0-70
6.2
0-80
7.8
0-90
9.5
0-100
11.4
PASSING, 45-65 MPH
2.1
QUARTER MILE
13.3 sec @ 106.9 mph
BRAKING, 60-0 MPH
117 ft
600-FT SLALOM
67.6 mph (avg)
LATERAL ACCELERATION
0.90 g (avg)
MT FIGURE EIGHT
25.8 sec @ 0.71 g (avg)
TOP-GEAR REVS @ 60 MPH
1800 rpm
CONSUMER INFO
BASE PRICE
$61,565
PRICE AS TESTED
$61,565
STABILITY/TRACTION CONTROL
No/yes
AIRBAGS
Dual front, front side
BASIC WARRANTY
3 yrs/36,000 miles
POWERTRAIN WARRANTY
1 yr/12,000 miles
ROADSIDE ASSISTANCE
3 yrs/36,000 miles
FUEL CAPACITY
15.7 gal
EPA CITY/HWY ECON
15/22 mpg
RECOMMENDED FUEL
Unleaded premium
[/b]
POWERTRAIN/CHASSIS
DRIVETRAIN LAYOUT
Front engine, RWD
ENGINE TYPE
VALVETRAIN
SOHC 3 valves/cyl
DISPLACEMENT
301.6 cu in/4942 cc
COMPRESSION RATIO
10.5:1
POWER (SAE NET)
400 hp @ 6000 rpm
TORQUE (SAE NET)
REDLINE
6500 rpm
WEIGHT TO POWER
9.0 lb/hp
TRANSMISSION
5-speed manual
3.73:1/2.54:1
STEERING RATIO
15.7:1
TURNS LOCK-TO-LOCK
2.8
BRAKES, F;R
WHEELS, F;R
TIRES, F;R
DIMENSIONS
WHEELBASE
107.1 in
TRACK, F/R
62.8/63.9 in
TURNING CIRCLE
33.4 ft
CURB WEIGHT
3602 lb
53/47%
SEATING CAPACITY
HEADROOM
38.6/34.7 in
LEGROOM
42.7/30.3 in
SHOULDER
55.4/53.4 in
CARGO VOLUME
13.1 cu ft
TEST DATA
ACCELERATION TO MPH
0-30
1.8 sec
0-40
2.7
0-50
3.7
0-60
4.7
0-70
6.2
0-80
7.8
0-90
9.5
0-100
11.4
PASSING, 45-65 MPH
2.1
QUARTER MILE
BRAKING, 60-0 MPH
117 ft
600-FT SLALOM
67.6 mph (avg)
0.90 g (avg)
MT FIGURE EIGHT
1800 rpm
CONSUMER INFO
BASE PRICE
$61,565
PRICE AS TESTED
$61,565
No/yes
AIRBAGS
BASIC WARRANTY
3 yrs/36,000 miles
POWERTRAIN WARRANTY
1 yr/12,000 miles
ROADSIDE ASSISTANCE
3 yrs/36,000 miles
FUEL CAPACITY
15.7 gal
EPA CITY/HWY ECON
15/22 mpg
RECOMMENDED FUEL
Unleaded premium
I think Motortrend made a mistake. They are saying Iron block, Aluminum heads. Unless Saleen switched to an Iron block (I'm under the impression all they did was stroke the existing block) then I'd say it's just a typo.
I plan on keeping as is (modless).I truely believe that the HP and Torque are enough for me so why mess with it. It already has a CAI of sorts through the shaker and air box which has no bottom. Yes I plan on taking it to the track this summer to see what it can do.
ORIGINAL: Menace
Today’s Saleen / Parnelli Jones Limited Edition Mustang reflects the same authentic vintage attitude but comes complete with a new Saleen 302 cid V-8, 3-valve engine. This engine produces a whopping 400 horsepower at 6000 RPM, and with 390 ft-lb of torque at 4000 RPM. The high compression engine transforms a normal drive into an exciting thrill ride. Awakening the senses, the new Saleen engine is equipped with a high compression, high revving valve train, utilizing forged pistons, rods, and crankshaft and a lightweight, aluminum flywheel. Top-performance calibrations are thanks to Saleen’s PowerFlash TM technology.
mungodrums
Sep 28, 2015 10:54 PM
