Do you put fuel system cleaner in the tank every once in a while?
My car has 3500 miles now, and I'm thinking to put one in. But I've heard bad things about it. So do you put fuel system cleaner in the tank every once in a while?
RE: Do you put fuel system cleaner in the tank every once in a while?
ORIGINAL: Menace
I think it's been said to avoid such.
From what I understand, it's a good idea to use an additive with Chevron Techron occassionally to keep the intakeclean of deposits caused by the EGR and combustion blowback, especially if you don't vary the gasoline diet very much from the Wawa or Royal Farm Store.
As long as you use a Top Tier Fuel you should not need this stuf. If however you want to use it then use the Techron. Also fuel additives cannot keep the intake clean since the gas never touches the intake expect for just before the intake valves.
Richard
Richard
if I were to use one I'd try http://www.jegs.com/webapp/wcs/store...46584_-1_10317the race one
the small amount ofnitromethane might counter the octane increase but should burn hotter and clean carbon off
ORIGINAL: Ford_Dude
If you want a REAL Octane Booster use this.
http://www.torco.com/cart.php?m=product_detail&p=8
Richard
I run Chevron fuel system cleaner every other oil change. My wifes focus is coming up on 70k and I have had no problems. We use the same cleaner for a SSM put out by Ford. This is mainly for fuel gauge concerns with sulfur build up and our engineer said running it won't harm anything as long as used by the proper instructions on the bottle.
