Ram air.
Old Mar 24, 2007 | 08:09 PM
blitzed589's Avatar
blitzed589
Default Ram air.
Before i go and do something stoopid. Would cutting out a the square in the california dream hood to make space for the mustang shaker system interfere with the way the hood functions, or is the ram air passage ways in the hood too far forward from where i would be cutting to interfere?
Old Mar 24, 2007 | 09:08 PM
gmascagni's Avatar
gmascagni
Default RE: Ram air.
I have an 05 and I cut out the center for a CDC shaker. I never had the problem reported by many regarding the unstable hood at high speeds but my shaker hood works great. There is not interferance in the 05 hood. Just put a 2x4 under the hood and cover it with some towels so shavings go go everywhere. It's routed through the back in the 05. The california edition may be diffrent.
Old Mar 24, 2007 | 09:38 PM
blitzed589's Avatar
blitzed589
alright thanks for the input.
Old Mar 25, 2007 | 08:04 AM
bomb79's Avatar
bomb79
cervinis sells a ram air kit that i think would work great with the cali dream hood ,if those holes in the hood are functional.
Old Mar 25, 2007 | 08:38 AM
likemike99's Avatar
likemike99
no no no. don't cut. on the cali dream hood you are correct . the vents are only like a foot from the front of the hood. you can do it but the the vents will not function. although if you have a shaker it has the scoop which functions as a ram air. . I guess I am not sure of your main concern. if you want the vents on the hood to be functional then don't add the shaker. If you add a shaker it has the scoop and the hood vents serve no point but looks. not sure how that would look- front vents and center hood scoop.
ccdguy
Sep 19, 2015 05:20 PM
uedlose
Sep 10, 2015 03:30 PM
MXBT187
Aug 20, 2015 02:36 AM
SANDY21
Aug 17, 2015 02:41 PM
elraun
3.7L V6 Technical Discussions
Aug 9, 2015 04:32 PM
