Wheel and Suspension Mods
RE: Wheel and Suspension Mods
Its got more than you need/want perhaps, but it is very nice.
front sway is not needed as the stock is fine and the UCA and UCA mount can be a PITA.
Tillmanspeed has a group buy over on another forum and you might be able to get in on that still.
ORIGINAL: howarmat
Concerning the UCA and UCA mount, do you mean they are a PITA when installing the sway bar? I'm going to have a professional do the installation. I wonder how much that'll cost me.
I also found the following BMRpackage on the website. Will this be a good idea or should I just go with just LCA's for a couple hundred dollars cheaper? By the way, I couldn't find UCA's...
BMR Level 1 Package Includes:
[ul][*]Billet Aluminum Lower Control Arms w/ Polyurethane Bushings (Part # TCA027)[*]Upper 3rd Link w/ Polyurethane Bushings (Part # UTCA017)[*]Upper Control Arm Mount (Part # UCM001)[/ul]
Thanks for all the help. I have a lot of questions, but now learning a lot!
ORIGINAL: Maineiac
Read the post by CrazyAl here and you should know what you do need or maybe not.How far you want to take it is up to you, but what has been mentioned above is generally all that is needed for proper install.
https://mustangforums.com/m_1696246/...tm.htm#1696246
I have an 06 GT convertible. I got the following suspension mods professionally installed. ($2,400 out the door- Parts/Labor/Tax)
1. Eibach Pro-System Plus Suspension Kit
2. BMR adjustable chrome-molly panhard bar
3. BMR camber bolts
4. Metco billet Lower Control Arms
3. BMR camber bolts
ORIGINAL: TheDarkPath
I have the BMR tubular LCAs with relocation brackets. I like them even though the install was kind of a pain. One of the brackets was bent and the spacers were too long. a vice, some elbow grease, and a hack saw took care of all of those minor issues. BMR's quality is top notch. I also have their radiator support/front swaybar delete and it was a perfect fit.
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
