Spark Knock
Old Mar 26, 2007 | 07:50 PM
doode's Avatar
doode
Default Spark Knock
Ok,
So I got back from a 500km round trip from Vancouver to Seattle.
Full talk of Chevron 89 octange gas ( what i always put in ), no problems.
I get back into Canada, fill up again with Chevron 89 octane.
Ive put on about 200km so far with this tank and i get constant spark knock at every shift !
This is the second time ive had this problem. 1st time was again after a 500km trip down to seattle and back, but the difference is the 1st time i filled up with ethanol blended gas down in Seattle so i thought that was the cause of the spark knock. Spark knock is still happening even with Canadian gas.
Ive been warned by the dealer not to put in any higher octane gas as it can coat the engine parts and harm performance, but this is annoying.
Its not knocking through the entire RPM band, but at each shift once you get back on the gas (be it light / mild/ or full on WOT) it makes a real noticible knocking noise for a split second.
Any suggestions? Can I take it back to the dealership and have them inspect the timing ?
TIA
Old Mar 26, 2007 | 07:57 PM
Jays Mustang's Avatar
Jays Mustang
Default RE: Spark Knock
Even in the owners manual it warns about Canadian gas. Get that crap out of it.
Old Mar 26, 2007 | 08:13 PM
doode's Avatar
doode
lol
well i live in Canada so its not like i have a choice where i fill
ive had spark knock here and there before this trip, but this time its so much more noticble than before as its in each gear
Old Mar 26, 2007 | 08:20 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
It could also be another noise. There is a tsb for an exhaust rattle from the isolator hangers that can sound like a pinging.
Old Mar 26, 2007 | 08:58 PM
2cokeman's Avatar
2cokeman
I have knock too, also had it in the 06, Did the dealer say 89 octane was ok??
Old Mar 27, 2007 | 04:07 AM
HypromanGT's Avatar
HypromanGT
I have experienced this noise too, as you say, for a split second if you get on the gas right after an up-shift. I equate it to 2-3 metal valves closing one right after the other. Click click click really fast, and then gone.
I am almost 100% sure it's not an exhaust rattle (I've had that too, unfortunately :-\). The sound is definitely coming from the engine compartment.
I'm stock, untuned, live in the US, and use 87 gas. I tried 89 gas a few times and the noise didn't seem to change at all.
Old Mar 27, 2007 | 11:59 AM
PROMETHEUS PRIME
We just had a stang in at my work that had what appeared to be the same issue. Ended up needed lash adjusters.
Old Mar 27, 2007 | 10:35 PM
doode's Avatar
doode
ORIGINAL: PROMETHEUS PRIME
that a labour intensive job?
how would i convince the dealership to look at this?
Old Mar 27, 2007 | 10:41 PM
PROMETHEUS PRIME
Are you out of warranty cause if so labor would be costly.
If you still have warranty bring it in a tell them what is going on.
Old Mar 28, 2007 | 03:45 AM
doode's Avatar
doode
well im still waiting on the dealership (its been over a month)to get back to me in regards to a transmission problem, and this spark noise type of noise is just another thing to add to the list
this is a pain in the *** as ive got my tuner / intake / h-pipe and flowmasters all set to go in, but i cant do anything until i know my motor and driveline is in tip top shape
off to the dealership i go again on thurs
