Spark Knock
Sounds like a classic case of spark knock to me. It ran fine, you filled up the tank, it knocked. Seems like the gas may be a little low in octane. I would put in some 91 or 93 and see what happens. If the sound goes away, then you know it must be spark knock.
ORIGINAL: Lees07GT
now, in any gear, get on the throttle from moderate to WOT and you will hear the distinctive knocking noise for a good 2 seconds
ahh well, see what the dealership says
well shop forman took it for a rip, said it was normal and that its even printed in the manual that spark knock may occur and is normal
Be that as it may, but if i get on the throttle each time and it knocks, that CANNOT be normal.
He said drive it for a while, and bring it back at its next oil change and he would look into it further if it continues (about 1000km away)
Hell, my volvo with a poorly tuned carb and +8 degrees of timing doesnt even knock this hard or often.
Will pulling the battery and letting the ECU reset help in this case?
jessicarabbit
Sep 25, 2015 12:41 PM
