Keeping a sub in place...
Old Mar 27, 2007 | 04:50 PM
chidrock's Avatar
chidrock
Default Keeping a sub in place...
I don't have the Shaker, but I have a single sub in my trunk that I want to keep from sliding around. How do you guys without the shakers keep them in? I was think about getting some brackets, but I don't know if that will be bad for the plywood trunk bottomover time...would it just make the holes get bigger since the sub box is so heavy?
Old Mar 27, 2007 | 04:57 PM
schapman's Avatar
schapman
Default RE: Keeping a sub in place...
I haven't look in my trunk for the mounting location but there should be mounts for the shacker 1000 sub on the passenger side.
howarmat's Avatar
howarmat
s197 Junkie
You can buy a box that fits in stock shaker 1000 spot and there is a hole were you put the bolt to hole the box.
Old Mar 27, 2007 | 05:03 PM
chidrock's Avatar
chidrock
Thanks, but it's too late for the box that fits because I already have one that was put in. I have some extra stuff in the trunk to keep it from sliding too far, but I want to take that stuff out for something else that I don't want the sub to crush...
Old Mar 27, 2007 | 05:23 PM
drbobvs's Avatar
drbobvs
Take the woofer out and screw throught the bottom of the box into your trunk floor. All you need is a 1" machine screw.I used a 11/4" DeckMate screw with some silicone sealant on it. It goes through real easy. Just check underneath where you're srewing first to make sure the area is clear.
Old Mar 27, 2007 | 06:03 PM
Speedyejl's Avatar
Speedyejl
Drilling is a good option, when I put a box in a spot though with the gas tank underneath it or didn't want to drill I made a new trunk floor out of 1/2in plywood. Shape it using the stock floor, make a cutout for you subbox, and wrap it with carpet. Works great and wedges in place. Just make sure your not putting pressure on any plastic trim.
Old Mar 27, 2007 | 07:06 PM
hogpowr's Avatar
hogpowr
A temporary fix would be bunge cords. You could also access the spare.
Old Mar 27, 2007 | 08:56 PM
lacountyfireman's Avatar
lacountyfireman
You can use Steel "L" brackets from home depot/lowes. Usewood screws into the box and self tapping metal screws to mount the sub box to the trunk floor. Be aware of what is below the surface you are drilling into. Use the shortest screw for the job.
Old Mar 28, 2007 | 12:53 AM
JibStyle's Avatar
JibStyle
chidrock:
velcro. i had the exact same problem as you, and i was afraid to drill holes because i thought they might damage the plywood. my dad happened to have some scraps from old sheets of velcro lying around, so i cut small rectangles of the scratchy half of the velcro and put two pieces back-to-back with the adhesive sides touching to make double-sided scratchy velcro. i only had to cut two rectangles about 1.5" x 3" each and i stuck them in between the sub box and the trunk carpet and my sub hasn't moved since
Old Mar 28, 2007 | 02:27 AM
FredTT's Avatar
FredTT
Take out your spare, put the box in your wheel well. It won't move. Thats how I have mine (No trunk space though)
~Fred
