What is needed for 11.90s N/A
Old Mar 29, 2007 | 04:38 AM
stangoil's Avatar
stangoil
Default RE: What is needed for 11.90s N/A
Martymoose
have you ran you car on 1/4 mile?
Old Mar 29, 2007 | 04:39 AM
Ford_Dude's Avatar
Ford_Dude
ya I recall some one posted something like that but I wouldn't trust it
the stage 3 cams should be good for N/A but not S/C the p/p should be good for both
the stoker should still be good with a S/C but you'd want dish pistons to lower the compression (if stoker and S/C at the same time) if not then you'd want semi stock ratio but if no S/C then go high compression
An additional oil cooler and trans cooler should help prolong the engine life
Old Mar 29, 2007 | 04:44 AM
stangoil's Avatar
stangoil
i dont have stage 3 cams these are made for 4:10 gears and superchargers http://www.compcams.com/Technical/Ca...7/Images/2.jpg
Old Mar 29, 2007 | 04:49 AM
MartyMoose's Avatar
MartyMoose
Hasn't seen the track - the weather here sucks (NW) plus I've never been on the track before.
I guess now's a good time to learn with a blown GT, huh.[sm=crossbonesgif.gif]I'm more concerned about making the car look bad!! [sm=icon_rofl.gif]
I can see it now: (over the speaker system at the track)"In the left lane is a 2007 supercharged Mustang GT..." and give 'em a 20(+) ET!!! [sm=insomnia.gif][sm=oopssign.gif][sm=signs006.gif][sm=owned.gif]
I do need to get out there and try it but it wont be until we get some decent weather - when ever that'll be.
Old Mar 29, 2007 | 04:52 AM
stangoil's Avatar
stangoil
same problem, the fords dealership that built my car the svt guy races 9 second car is going to run the car aftter i get the bugs out
Old Mar 29, 2007 | 04:56 AM
TheDarkPath's Avatar
TheDarkPath
ORIGINAL: Ford_Dude
Yeah, the stage 3 cams would be for the N/A setup. If i go FI, then i'll probably still do cams but one made for FI.
Will my fuel pump and injectors be good with the N/A mods mentioned? Will I need to go with colder spark plugs?
Old Mar 29, 2007 | 05:02 AM
MartyMoose's Avatar
MartyMoose
ORIGINAL: TheDarkPath
ORIGINAL: Ford_Dude
I've heard the stock fuel pump is good for ~500rwhp (plus more but I dont know how much more). Asking whether the pump and injectors support your build, a dyno with a/f should be able to answer this. The colder plugs are a safeguard/deterrent against FI detonation and probably higher compression?
Old Mar 29, 2007 | 05:07 AM
stangoil's Avatar
stangoil
we change plugs on the cam change and fuel is ok problem gear cams and tci 3500 stall all went in at one time so is the transmisson the cams or gears or all the above. BMR and diablo have a 9's auto the gust built with same as mine but 17 psi the have same problem they are write the program.
[IMG]local://upfiles/52448/BCB75E063A96493089BADB013A791AC7.jpg[/IMG]
[IMG]local://upfiles/52448/401F044F154248238D49C4B447C4A242.gif[/IMG]
Old Mar 29, 2007 | 05:23 AM
Ford_Dude's Avatar
Ford_Dude
ORIGINAL: MartyMoose
ORIGINAL: Ford_Dude
The cooler plugs on FI is because the s/c can blow-out(according to holly)the spark (higher density air has higher electrical resistance) so some older cars would put colder plugs and hotter ignition
it your stayingN/A no nos I'd say stick with the stock plugs
detonation is where the a/f mix ignites on its own before the spark plug
if you stay N/A ask the make of the stroker kit about the plugs
Old Mar 29, 2007 | 05:40 AM
MartyMoose's Avatar
MartyMoose
ORIGINAL: Ford_Dude
ORIGINAL: Ford_Dude
Thanks. I thought the colder plugs were due to hotter plugs actually igniting the mix (like a glow plug) prior to spark timing (pre-ignition/detonation).
