What is needed for 11.90s N/A
I know there are easy answers like supercharger/turbocharger or nitrous but I'm wanting to run 11.99 or better in the 1/4 N/A without nitrous.
So far, this is my plan:
-My current mods (see sig)
-3.73 gears
-Torque Converter (unsure of stall)
-Charge motion delete plates
-MT E/T Street DRs
-Aluminum Driveshaft
-5.0L stoker kit
-Tubular K-member and A-arms
-Ported and polished heads with 3-angle valve job
-Comp stage 3 cams
Will this setup get me 11s?
Is there anything i'm missing that i'll need...fuel system upgrades, rearend upgrades, etc?
This will be a long-term project so I'm not looking to have this done next month or anything.
-3.73 gears
-MT E/T Street DRs
-5.0L stoker kit
-Comp stage 3 cams
RE: What is needed for 11.90s N/A
this is just speculation but if you do cams you might actually benefit from the TB and the C&L racer
and with the stroker I'm sure those would help even though the TB doesn't help the stock engine and the racer compaired to the street on the stock motor don't have a big diff
ORIGINAL: Ford_Dude
ORIGINAL: howarmat
I would agree with this but with the money you are talking about why not just do a SC??
ORIGINAL: Ford_Dude
getting to 11's is not easy i have s/c 9psi cams,4.10 (ect see below) and now the 3500 stall and camshafts and will be high 11's i am at 2800 ft which hurts me but if the mickeys hook up may be mid 11's will best unless i raise the boost i dyno 2 weeks ago at 400 rwhp @ 3300 ft above sea level
ORIGINAL: stangoil
I should have an easier time than you (not saying it's easy) getting into the 11s since i'm basically at sea level (Houston, TX).
mustangman2424: Yeah, that's my other option...forged internals, whipple HO, and built tranny. One of these days i'm just going to price out all the options and see which looks best. I mainly wanted to see if I did all the above, am I missing any vital upgrades such as fuel, rearend, etc.
well right now i tecmotion, bmr, comp cam, diabloand ford trying to make this thing shift properly been to dyno 3 times and new problem after fix last problem. the gears on the hiway suck but the feel is great. if i was not going to race the car i would go to 3;73
I think it's great trying to get low #'s on all motor - good luck with your build.
I think these forums are a really good place for a lot of info. Additionally, if I were you, I'd kook-up with a good local speed shop/tuner.
I've heard that there is a calculator out there that can calculate how much hp/tq you'll need to accelerate the weight for the target ET? Anyone seen the calculator I'm talking about (maybe I'm having a 'shroom flashback)? [sm=icon_beat.gif]
