Raptor Install..56K Beware!! Tons o Pics
#41
RE: Raptor Install..56K Beware!! Tons o Pics
Great Write up.... Next time I am at Disneyland I will drop my car by so ya can add one for me.... HAHAHHA.. Thanks again for all the details.
#42
Ok, that would explain it, I must of missed a earlier post which changed your steps to not use that power source? All dip switches are in the down position, if your holding the raptor with the led's pointing to the left.
Let me know when you confirm the newpower sourceused,and I'll head outand change.
#44
Ok, I am using number 14, which has an empty space below it, which allows for enough room for the add a circuit. I swore I edited that, but just checked and did not. My apologies. I have now edited it.
The dipswitches as you describe are correct. The directions are a bit confusing, as the switches are actually white, but the directions illustrate them in black, which makes it look backward.....
It's gotta be your power source currently not being switched. And I did verify the light show sequence upon start up.
Let me know,
Mike
Let me know,
Mike
#45
Ok, I used #14 fuse slot, and now the sequence lit up as it should!
Thanks
Thanks
