Improving Traction Question
Old Apr 1, 2007 | 07:26 PM
Dman23's Avatar
Dman23
Default Improving Traction Question
Just wondering if there is anyone who know's if there is a traction bar out there for an 06 mustang gt? If so I am thinking about getting one if I can find it any recommendations or tips?
Thanks
Old Apr 1, 2007 | 09:58 PM
TheDarkPath's Avatar
TheDarkPath
Default RE: Improving Traction Question
Get some adjustable lower control arms or non-adjustable with relocation brackets. BMR makes good quality suspension parts. Also look up CHE or Spohn.
Old Apr 1, 2007 | 10:56 PM
drbobvs's Avatar
drbobvs
+1 lower control arms will solve most of your off the line traction issues. Don't forget Steeda too.
Old Apr 2, 2007 | 01:30 AM
91GT's Avatar
91GT
So if I got some BMR lower control arms, is it something I can put on myself or not? Is there anything else I should be adding while im there?
Old Apr 2, 2007 | 01:40 AM
androdz's Avatar
androdz
I ♥ Acer
ORIGINAL: TheDarkPath
Darkpath you got your info wrong. Get adjustable lower control arms and get relocation brackets if you plan on lowering your car.
https://mustangforums.com/m_2727670/tm.htm
Andrew
Old Apr 2, 2007 | 01:44 AM
TheDarkPath
Depending on what you have planned for the future, you may want to do an adjustable upper control arm while the car is in the air. This will almost be a necessity if you'll be doing a 1-piece driveshaft later on since you may need to adjust the pinion angle. There is a very good post about this someone on here. The UCA will also provide more durability over the stock UCA and adjustablility is always a plus.
I did the BMR LCAs and relocation brackets in my driveway using jackstands and hand tools (the hose on my air compressor had busted so everything was done with hand tools) with the help of my Dad. A 2nd pair of hands always helps. The install wasn't too bad but the spacers that came with my relocation brackets were too long (way too long) and I had to take a hack saw to them. One of the brackets was also too narrow but I was able to bend it out. Brenspeed was really cool about it and said if i couldn't make it work, they'd take them back, open up another box to make sure they were right, and send me a new pair. You can order any BMR parts from Brenspeed, even if they aren't listed on Brenspeed's website. Go to http://www.bmrfabrication.com/.
If you're only going to be drag racing and not road racing (autocross), then i'd suggest the BMR radiator support/front swaybar delete. It sheds about 26lbs off the front and allows the front to raise up a little more when launching. That was a really simple install.
Old Apr 2, 2007 | 01:50 AM
TheDarkPath
ORIGINAL: androdz
Andrew
If you look in the link you posted and at the picture in that post, there is an "aggressive setting" for the relocation bracket where the back of the LCA is lower than the front...thus improving traction. If you lower the car, then it's a necessity to adjust the LCA angle so it's not pushing the rear end upwards which would kill traction.
Old Apr 2, 2007 | 04:55 AM
androdz's Avatar
androdz
I ♥ Acer
Hi again, on your second post you state to get adjustable LCA's or LCA relocation brackets and non-adjustable lcas. Adjustable lcas and relocation brackets do two separate things. Relocation brackets change the LCA Angle and the adjustable LCA's change the pinion angle. It is much better to have adjustable LCA's and a fixed UCA. Also while you are doing that You might want to do the UCA mount and the adj.panhard(if you lower your car) with the upper panhard support. It is like 300$ more for those parts and the install isn't that much because you have to remove them anyways during the install, might aswell replace them with better parts.
Andrew
Vrooom
Feb 21, 2016 05:25 PM
treesloth
Sep 28, 2015 07:03 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
