PULLY HELP!!!
Old Apr 4, 2007 | 11:55 PM
06harleysprayin's Avatar
06harleysprayin
Default PULLY HELP!!!
WATS up FORD bro's..now i don't own a stang but i'm wondering if u guys can help me i recently installed sum motoblu underdrive pulleys..they worked fine the 1st night & 2nd day but when i went to start it the other day i got a mean squeaky noise when i put it in drive..i heard it may be sum antifreeze which may have gotten on the pulleys &dried but wouldn't that have been heard tha 1st night or at least the 2nd day im just wondering if u guys have had the same prob..or if u know wat is goin on or can give me sum ideas..
any help is better than none..
Old Apr 5, 2007 | 12:41 AM
Smokem's Avatar
Smokem
Default RE: PULLY HELP!!!
I put the Steeda UDP on worked for about a week and made it through a Dyno tune then I started to get a Squeek which turned into a squeel. First after discussions with people decided it was a premature tensioner pulley. So I changed the tensioner and still the Squeek. Finally took a look at the balancer pulley it was running true butthe bolt was pretty easy to remove. I had torqued it down to steeda spec it said tq to like 89 then back off and tq to 65 or somehting like that i don't remember off the top of my head. While I was my performance shop trying to figure it out they said they put them all on with an impact and have never had an issue. So when they took the impact wrench to it it went on another 16th of an inch then half a turn and now no more squeel perfectly fine. The other option might be if your water pump pulley has holes in it it might just be whistling becasue of the airflow.
Old Apr 5, 2007 | 12:56 AM
spdbrake's Avatar
spdbrake
The high torq is to seat it. Then loosen it and re-torq to the lower setting.
While using an inmpact wrench to remove the bolt fine, it is not calibrated and has an unknown setting torq to install the crank bolt.
Make sure you change the belt when you install the pulleys also.
Most of the squeal can come from an old belt.
Old Apr 5, 2007 | 01:02 AM
Smokem's Avatar
Smokem
Most of the pulley systems for the S197 do not require a belt change. My tensioner does sit closer to the stop but this might just be Steeda's spec for usingstock belt. But spdbrake is right about it might be the belt. It is the belt, pulley, or a bearing in an idler pulley.
Old Apr 6, 2007 | 01:52 AM
06harleysprayin
thanks for ur help..yea i had changed the belt..already i ended up puttin on the GATORBACK belt but i'm pretty sure its got to be the torque issue..my cuzin was sayin up & down it has to be dirty so i know its either dirty or its loose..thanks for helping get my 06harley f-150 back on the road..
Old Apr 6, 2007 | 09:07 AM
Daniel60's Avatar
Daniel60
mine belt was noisy until finally it made it self at home.
ctgreddy
Sep 20, 2015 08:35 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
96mustanggt46
Jan 12, 2004 02:52 AM
VicsGT
Nov 25, 2003 07:07 PM
skatepony
Jul 30, 2003 10:12 PM
