Larger Rims Decrease PErformance???
Old Apr 5, 2007 | 11:58 PM
bowiel's Avatar
bowiel
Default RE: Larger Rims Decrease PErformance???
ORIGINAL: Lees07GT
It is also important to consider overall tire/wheel height. If your new combo has a taller height than what you started with, you will have reduced the engine rpm at a given speed. This has thesame effect as reducing your rear end gear ratio. Anytime you go to a larger wheel, you should go with an appropriate lower profile tire to maintain your overall gear aspectif, in fact, you want the effective gearing to remain unchanged.
Ahh thanks for the info, I went back and checked my original tire size on the 16s and the hight was off compared to the ones that were recommended for the rim which are actually the standard for the GT. Hope that made sense, anyways, again as I said earlier, I really messed up by not accurately checking the tire sizes before purchase. I guess i can either sell these or just ride with them till it's time for new ones.
Old Apr 6, 2007 | 12:02 AM
bowiel's Avatar
bowiel
ORIGINAL: CrazyAl
1. Speedo error: Only the outside diameter of the tire affects your "gearing" and speedo error. Rim size (16, 17, 18, 19, 20, etc.) has nothing to do with this.
2. Larger rims are worse for acceleration even if the total package is the same weight as what you had before. Inertia is derived from the product of mass and radius. Larger wheels carry most of their weight at a larger radiust. For example, suppose your stock 17" wheel and tire package weighs in at 50 lbs. You switch to 20s, and suppose those also weigh 50 lbs. (which means very light 20s). The 20's have higher inertia than the 17s because even though the weight is the same, the 20" set carries that mass further out from the center of the wheel. In order for a 20" wheel & tire package to have a the same inertia as a smaller-wheel-diameter package, the 20" combo would have to be lighter, which is extremely unlikely.
3. Technically drilled brake rotors are lighter, so switching to them would save some weight. However it is a TINY bit of weight. I'd be suprised if it was more than 2 or 3 ounces per disc. The only truly effective way to save weight is to buy race-oriented wheels which are actually designed for light weight, not looks like most wheels are.
Thank you very much for the insight. It makes sense and I think someone said to me that I had to decide what it was I actually wanted to achieve, either looking nice or performance. Since mines a V6, I guess I'll opt for the looking good till I am ready to graduate in the performance aspect of the mustang.
Old Apr 6, 2007 | 12:18 AM
armour845's Avatar
armour845
CrazyAl, thanks for pointing out the outer diameter of the tire effects the speedo. That was whatI was trying to say, but may have notbeen exactly clear. As far as weight, I couldn't beleive it either but the scale doesn't lie, it's been telling me how fat I am for years now, but the 20" inch tire and wheel weighed exactly the same as the stock 17" bullets and tires. Either way I can't feel any difference in performance physically.
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
