Installing UDP's
Old Apr 8, 2007 | 02:26 PM
05 Mustang GT's Avatar
05 Mustang GT
Default Installing UDP's
Hello All
Whats involved with installing UDP's? I did a search, another guy asked the same question with no replies. Is it something that can be done easily, any special tools? Puller?
Thanks in advance.
_____________________________
05 Mustang GT 5 Speed
Mineral Grey, IUP, Plenum Cover, Billet accesories, Boss Striping Kit, Pypes Violators, Hurst Shifter
Old Apr 8, 2007 | 02:55 PM
wingman75's Avatar
wingman75
Default RE: Installing UDP's
ORIGINAL: 05 Mustang GT
Hello All
Thanks in advance.
Good question, but I don't have an answer, I want to find out too. I hear its easy but no one has described the process in detail.
Anybody?
Old Apr 8, 2007 | 03:01 PM
PERTANO's Avatar
PERTANO
There was a link on this forum somewhere. But it's very simple. You just need to remove the fan assembly out of the way. and the overflow reservoir. It's self explanitory once you get in there and do it. The you have plenty of room to hit the pulley bolt with an impact to remove it. Get yourself a pulley remover tool and then install the new one. The install procedure is a bit tricky but basically you press it one then torque it. I did it a slightly less "PROPER" way but haven't had any problems with it. Search for the UDP install and you should find the link.
Old Apr 8, 2007 | 03:12 PM
wingman75's Avatar
wingman75
Thanks I'll look for it.
Old Apr 8, 2007 | 04:04 PM
howarmat's Avatar
howarmat
s197 Junkie
http://www.musclecarblog.com/story-4...rdrive_pulleys
http://www.stangnet.com/Tech-Article...ll-070211.html
http://www.cherod.com/mustang/HowTo/Pulleys.htm
Old Apr 8, 2007 | 04:39 PM
wingman75's Avatar
wingman75
Matt, thanks for the links. Very good instructions in all 3 of them for a novice like me.
Old Apr 8, 2007 | 05:18 PM
odiaz's Avatar
odiaz
I wrote the instruction on www.cherod.com/mustang. The trick for me was finding a compact impact wrench small enough (5" or less) to fit between the radiator fan and the crankshaft. I did not want to go through the trouble of removing the Antifreeze reservoir, Steering fluid reservoir and fan shrowd assemby. I wound up borrowing one from Sears the first time. If you are going to do it a few times it might be worth it to buy one.
The other key point was the altenator bolt. If your kit does not come with a shorter bolt, you will need to cut or grind down one of the alternator bolts. I did not notice that one of the bolts barely rubbed against the belt and shortly after I started the car, the belt was torn to shreds.
The last thing to remember is to reconnect all of the plugs you pulled. Ive done the Pulley install a few times now and every once in a while, I forget to re-connect the MAD and I wind up getting errors upon strat up.
Over all, this is a very simple install and definitely worth the effort.
Old Apr 8, 2007 | 05:22 PM
05 Mustang GT
Howarmat
Thanks for the info, I am ordering my CAI and tune this week, will add UDP's to the shopping list.
Old Apr 8, 2007 | 08:56 PM
bluene05GT's Avatar
bluene05GT
Has anyone done before and after dynos? I ready all different stories for UDP hp increase - everything from 10hp to just 1-2. If its a really low increase to me its not worth the cost and labor.
Old Apr 8, 2007 | 09:00 PM
howarmat's Avatar
howarmat
s197 Junkie
Its going to depend on your other mods but I think gains along 8-10 are closer to correct.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
