Hurst issues
Old Apr 9, 2007 | 10:43 PM
Speedyejl's Avatar
Speedyejl
Default Hurst issues
I've probably had my Hurst shifter installed for about 400 miles now.
The last two times I went to start up the car I had the following issue, with the shifter left in 1st gear it was jammed in first.
I had to use a little muscle to get it out of 1st into neutral. It shifted like normal for the rest of the ride, until about 2 days latter when I went for a drive again and I had the same issue.
Anyone else have a similar issue?
Old Apr 9, 2007 | 11:35 PM
billyjo's Avatar
billyjo
Default RE: Hurst issues
two things could be the problem, is the chrome handle on the correct side. it should be on the passager side and bolted on. If not you are binding it up. Two the bottom two rear bolts may lose or in wrong and have mis alligned the shifter. Hoped i helped
Old Apr 10, 2007 | 12:17 AM
05 Mustang GT's Avatar
05 Mustang GT
Good suggestions, I installed mine about 2 months ago. No issues. I hope you get it resolved.
Old Apr 10, 2007 | 07:08 AM
moosestang's Avatar
moosestang
Are you parking on an incline? If the driveline is loaded it might make it hard to get out of first. Try using the parking brake next time before you let off the foot brake.
I said might because i'm just guessing.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
firehorse02
Nov 16, 2015 11:28 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
