Brake ???
Old Apr 12, 2007 | 10:47 AM
Cobrakev's Avatar
Cobrakev
Default Brake ???
Is there a kit that will allow you to run 14" rotors, but still use the stock calipers?
Kevin
Old Apr 12, 2007 | 12:22 PM
offrdmania's Avatar
offrdmania
Default RE: Brake ???
Yes, Baer builds a 2 pc rotor assembly which gives you a longer slide for your stock caliper. I think its called the Eradispeed rotor?
Old Apr 12, 2007 | 01:11 PM
UrS4's Avatar
UrS4
Having a larger rotor will provide you with better heat dissipation and depending on the material and thickness it may not add weight so there is the potential for increased stopping power.
However, having a larger rotor while still using the stock caliper and pads will not make a significant difference in stopping power, distance, fade, etc. If you increase the rotor diameter you need to increase to larger pads so to take advantage of the larger potential surface where you can apply friction. As far as I have seen our stock pads are in full contact with the rotor so only increasing the rotor will change nothing, you need to put in larger and better pads. Actually if you put 14"+ rotors and kept the stock caliper and pads you will actually increase your stopping distance because the rotor will weigh more and take more force to slow down which you are not increasing by staying with the stock caliper and pads.
Bottom line, increasing the rotor diameter without increasing the pad surface area will not improve your braking, it may make it worse and these cars don't stop on a dime so I wouldn't do it unless you are getting a full kit.
Old Apr 12, 2007 | 03:22 PM
ANBAUTO's Avatar
ANBAUTO
I agree withUrS4.
If you were going to get just rotors i would just go with stock size rotors just get them cross drilled / slotted.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
