WHICH GEAR RATIO WOULD YOU INSTALL?
RE: WHICH GEAR RATIO WOULD YOU INSTALL?
4.10's
I have heard you can't feel much difference with the 3.73's. Some say it's a waste...But some say they like them a lot..maybe just because they have them? I don't know...
Biggest bang for the buck, get the 4.10's You might as well get your moneys worth. Gas mileage will go down 1-2 MPG
4.10s there is a 100 rpm diff between that and 3.90s, and a 1 mpg diff between 3.73 and 4.10s, also the 4.6 being a SOHC motor, has to rev to make the power, and, with the dog t3650's .62 5th gear, if your daily comute stays under 85 mph i would not heistate to put 4.30s in
If I had 3.31's. I would drop in the 3.73's.
Being that I have the 3.55's stock, I would not touch it as I would not want to go more than the 3.73 and it is not worth the effort coming from the 3.55's.
I drove mine with the stock 3.31's , then went to 3.73's. There ISa noticeable difference between the two. I find them to be a nice compromise between city and highway. I turn about 2000 RPM with the 3.73's @ 60 MPH (255/45/18 tires which are almost identical in height to the stock 235/50/18).
