Installed my O/R H-pipe last night......
RE: Installed my O/R H-pipe last night......
ORIGINAL: SonicBlue05GT
you could always put the stock mufflers back on with the O/R H. I tried that and it sounds pretty good. No drone at all and only loud when you stomp on it.
Drone city [:@] and loud as hell. Good loud from the rear of the car but bad loud inside the car.
I have the GTA mufflers and before the o/r h-pipe I had no drone at all. Now with the h-pipe I have drone in the 1000-1800rpm band and in the 3000-3500 band. I also have some wicked vibration in the trans tunnel.
I know I have to bend the mounting rods a little because once bolted to the engine they are really tight up against the bushings.
I am not happy at all. What can I do about the drone?
i also had an issue with the hangersand how they were welded on. we had to leave the h pipe in 2 pieces and put the hangers through the holes, the stick the h pipe together. it pulls against the brackets and the pipe is pulled a little up towards the car. this made the overaxle pipes not want to slide into the clamps. i had to get a hammer and hammer the clamp onto the overaxle pipes. actually the tight fit doesnt bother me, because now i know the overaxle pipes arent going to come loose .
the way i got to the top manifold nuts was with an impact, with a long extension, then a swivel, then a deep socket. my friend helped guide the socket onto the nut from the top of the engine bay. it takes a little work but you shouldnt have to cut your stock pipe.
With my Corsas on the back, I have no drone...but with their straight-through design, it's VERY loud. I haven't found an RPM range where drone kicks in more than stock.
I also had the intense vibration. I will eventully have to bend out the hangers on the h-pipe as they're too far back and they're rubbing the bushing and metal surrounding. This vibrates the crossmember and right into the interior. I "adjusted" it with an old socket and hammer but to do it right, i'll have to take the h-pipe off. Also, I wrapped the hanger with heater hose and zip tied it tight and that seemed to definitely help.
One of the other things I found was that the hanger off the h-pipe was rubbing a bolt and after bending it out, the vibration was gone.
Quick question. This is my first experience with o/r H-pipe or even a Mustang for that matter, so I'm not sure about the whole "drone" and specific pipe sounds. I have the Pype's o/r H with FRPP GTA'swhich i wanted for the DEEP muscle sound. If I'm at idle and i rev of the engine, at low RPM's it has the nice deep sound i was looking for, but at higher RPM's it has a slight "popping' sound. It isn't raspy sounding though.... I notice it a little while driving as well. Is it the GTA's? Is this normal? Thanks!
ORIGINAL: TacoBill
Put your factory catted H back on. Or, get some ear muffs.
The O/H isn't for everyone... that's a fact. I for one, love it. [sm=smiley20.gif]
ORIGINAL: bascho
I was about to order the H from Brenspeed...but now I'm concerned. I have FRPP stingers...they drone a little, but not bad at all. I want it loud outside, but not THATloud inside. Would I be better with Hi-flow cats and the H?
Some buddies have long tubes and an o/r X with stingers. I personally think that setup sounds like garbage...sooooo raspy! In my opinion, simply not a muscle car sound.
How about Long tubes and an H? Havent really heard this setup.
I was Flowmaster muffler with O/R H-pipe but it was too loud for my taste (im old). I swapped out the Flows for the stock mufflers and man I have to say its perfect! Slightly louder at idle than stock and wakes up nicely when you mash the throttle ...
ORIGINAL: TheDarkPath
Unfortunately I'll have to live with in until Sat.
ORIGINAL: Foose12
Now, from the back of the carit sounds really mean IMO.
Do you have the drone from hell just off start-up? When the idle is dropping slowly from 1500-1000rpms? The drone is so bad it vibrates my interior as if I had 15's in the trunk.
ORIGINAL: MustangEsq
TacoBill...I heard some of your YouTube clips of your o/r H and Stingers. Do you still have that setup? Sounded awesome from your garage and when you launched.
But, everytime I stand back and look at my Mustang, I expect it to sound exactly the way it does.. menacing! [sm=lildevil.gif]
I was getting a headache inducing droning from my off-road x-pipe, and it turned out to be the hanger in contact with the bracket on the car. I bent the pipe back so it wasn't in contact, and it cleared the drone issue up completely. Just loud and awesome.
