3.31 gears good choice for street only SC'd daily driver?
Old Apr 17, 2007 | 03:47 PM
EskimoPie's Avatar
EskimoPie
Default 3.31 gears good choice for street only SC'd daily driver?
Let me preface by saying I don't actually own a stang yet but I'm planning on buying an '07 convertable and installing a whipple HO SC on day one. I've read that many people pushing the ~475 RWHP that the whipple puts out have serious problems keeping the tires from spinning in 1st and 2nd gear. This car is going to be a daily driver for me, but due to being a vert will likely never see any drag strip passes (or maybe just one before they kick me off). I plan to thoroughly enjoy every single stop light however
All that being said, would the stock 3.31 gears be a good choice over even the 3.55's? I would think the whipple would have more than enough HP and torque to overcome the taller-gear which would itself provide a little protection against wheel-spin and make 1st and 2nd gear actually usable in stoplight to stoplight drags. Basically I want to try and avoid generating large amounts of white smoke every time I gun it off a light. Or would the 3.55's and a small amount of skill w/ throttle application and clutch engagement enable spin-free takeoffs and better acceleration?
Old Apr 17, 2007 | 04:03 PM
jaiasmit's Avatar
jaiasmit
Default RE: 3.31 gears good choice for street only SC'd daily driver?
I'd go ahead and spring for the 3.55s when you purchase. It's a $100 option when you buy, but it's going to cost you about $600+ to get them installed later (and you're going to want to get gears installed later). Although, if you think you might ever want to step up even higher to like 3.73s, it might not be worth the extra $100 up front. My guess is though that you'd be happy enough with the 3.55s to keep 'em.
You should look more at suspension upgrades to help your traction versus gear "downgrades" to slow down your power. Just my 2 cents.
Old Apr 17, 2007 | 04:07 PM
hammeron's Avatar
hammeron
stock, the gt500 has 3.31 as the final gear ratio
nice forward thinking on the whipple
Old Apr 17, 2007 | 06:38 PM
06SaLeEn's Avatar
06SaLeEn
I ♥ Acer
with that said the Saleen Extreme has 4.10 with 550 hp at the crank. I think 3.55 or 3.73 is going to be a good gear for a S/C
Old Apr 17, 2007 | 08:31 PM
forensicsteve's Avatar
forensicsteve
I think you get instant boost from a Whipple, so 3.55 or 3.73 may be the right choice. Going to 4.10 for example suits a centrifugal better (like Procharger)to get to the high rpm range a little quicker.
Old Apr 17, 2007 | 09:20 PM
cheftjpeck's Avatar
cheftjpeck
My saleen supercharged car has 3.31...if I had 3.73 I would be opening a monthly contribution to the tire network...IMO, I could not even imagine it...I almost went with 3.73 but recently changed my mind since supercharging...To me its a preference...
Old Apr 17, 2007 | 09:24 PM
06SaLeEn's Avatar
06SaLeEn
I ♥ Acer
I have the 3.73 in my saleen and have no issue, now if I choose to burn through tire I could, but 3.73 is ideal for f/I IMO
Old Apr 17, 2007 | 09:28 PM
Stkjock's Avatar
Stkjock
Retired Mod
I'd go for the 3.55's and def suspension upgrades for the added traction and bigger rubber on the rear..
Urambo Tauro
Dec 17, 2016 03:30 PM
spectreman
Mar 31, 2016 09:26 PM
squishbang
Suspension
Nov 2, 2015 03:42 PM
dochawk
Aug 25, 2015 08:25 AM
Figure8allday
Aug 22, 2015 11:11 AM
