AIRBAG QUESTION???
Old Apr 21, 2007 | 05:46 PM
2cokeman's Avatar
2cokeman
Default AIRBAG QUESTION???
I have had my STANG since Jan 30/07, I have never noticed the pass airbag off when the seat is empty before?? I am sure it never was, When someone gets onto the pass seat the airbag light off goes out, this isa only since my 85 pound 10 year old daughter was in the car today, So my question is am I nuts or DOES THE AIRBAG OFF LIGHT STAY ON WHEN THE PASS SEAT IS VACANT? AND GO OUT WHEN PASS ON SEAT??[sm=dontgetit.gif]
Old Apr 21, 2007 | 05:54 PM
bl1nk's Avatar
bl1nk
Default RE: AIRBAG QUESTION???
There is a weight sensor in the seat, where if the passenger doesnt weigh a certain amount (I believe its 100 lbs) then the airbag turns off, and the light will come on. When there is nothing in the seat, the airbag should be on, which means the light should be off. There is also a minimum weight, not sure how much it is though... so if you put something in the seat, like a bag, then it wont register enough weight to turn the airbag off.
Old Apr 21, 2007 | 06:24 PM
2cokeman's Avatar
2cokeman
When my seat is empty the light is on, when someone sits on the seat the light is off.
Old Apr 21, 2007 | 06:30 PM
OZ_Tambo's Avatar
OZ_Tambo
You should check the manual; it is related to weight of the passenger. I remember reading somewhere that if the child is under?? They should sit in the rear seat to avoid neck injuries caused by the airbag. I am sure your daughter is somewhere around the weight range that triggers the sensor.
Old Apr 21, 2007 | 06:55 PM
05Stang4Me's Avatar
05Stang4Me
No, my light is off all the time unless someone underweight rides and then the passanger airbag off light will display. The first time I saw the light was when I put my laptop in the front seat and I saw the light on. I went to the manual to see what was up I read what the deal was.
Old Apr 21, 2007 | 06:58 PM
2cokeman's Avatar
2cokeman
That was the way mine used to be untill today when my lightweight daughter sat in it. Now the light stays on?? Unless I sit on it, then it goes out?? Go figure[sm=WTFsgign.gif][sm=WTFsgign.gif]
Old Apr 21, 2007 | 09:06 PM
swoosh's Avatar
swoosh
Dunno what to say. I had someone lightweight sit in my passenger seat, light was on. Been off at all other times, when the seat is either empty or enough weight is there to enable the airbag.
Take it into the dealer maybe?
Old Apr 21, 2007 | 10:24 PM
americaniron's Avatar
americaniron
My wife, that I thankfully got rid of, weighed 100lbs. When she rode in the car, the light would go on and off, depending on how she was positioned. She was right at that threashold weight. It is a saftey feature to help prevent injury to children under a certain size. If you are under a certain weight and the bag deploys, you stand to have a greater chance of serious neck injuries. Smaller people are not high enough to meet into the center of the bag when it deploys. It will instead ride over their head shoving their cervical vertabrae at an odd angle, and with a hard and quick force, incresing the chance of injury. My father had a truck with a manual switch to disable the bag when children were up front. Now it's all automatic
Old Apr 21, 2007 | 10:42 PM
2cokeman's Avatar
2cokeman
Well, now the light is off and operating normally, Don't quite know what happended, maybe the sensor just got jiggled or something??
Old Apr 21, 2007 | 10:44 PM
lldsandsll's Avatar
lldsandsll
sometimes the light comes on for me when people are sitting there, but then it turns off after a minute
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
