installed SLPs, bad idle since
RE: installed SLPs, bad idle since
sorry, i mean it has a rough idle when sitting at a light or something. flucuates like 200rpm. i can feel the car shake/stutter a little. began happening right after install. any hope or is my car destined to be stock?
Im not sure about the rpm change, but as far as vibrating/noise, it is most likely the hanger vibrating against a piece of metal underneath the car. Try trimming the hanger or retracting the tips a little and see if that solves the shaking problem.
Any other mods? I recently installed my CAI and tune and the car does hunt +/- 200 rpm at lights. You can hear the engine rpm change. Fred from Evo said it was normal?
its my only mod.
but thanks for your help guys! i guess its not that unheard of. ill try disconnecting battery since i did not do that. i wish i had gotten in on that groupbuy! but i bought the SLPs right after i bought the car, hadnt even found these forums. anyways thanks!
Funny, I didn't disconnect my battery when I installed my exhaust (stingers) and they turned out ok. I know when my mazda had RPM problems it was the EGRvalve, but I would think it unlikely to happen already. Did you accidently move any of the pipes when you were doing the install?
