Mobil 1 Extended Performance
Old Apr 29, 2007 | 03:01 AM
NewMustang's Avatar
NewMustang
Default Mobil 1 Extended Performance
I was looking at the mobil 1 website, and seeing that the Mobil 1 Extended Performance doesn't list Ford WSS-M2C929-A as approved standands, but the regular Mobil 1 does.
So, why is that? Is it a good idea to switch to Mobil 1 Extended Performance, instead of the regular Mobil 1?
Old Apr 29, 2007 | 03:25 AM
ohnoesaz's Avatar
ohnoesaz
Default RE: Mobil 1 Extended Performance
You just said it does not meet standards, and then asked if you should switch to it...
Regular is better imo. But hey, ford has a spec for a reason so might as well follow it...
Old Apr 29, 2007 | 03:27 AM
srstang's Avatar
srstang
IMHO, Extended Performance is more hype and cost than benefit. It costs over 40% more than normal Mobil-1 with a claim of 15K miles. Your oil filter is the weakest link and should be changed more frequently, so you're better off using normal M1 and changing the oil at normal intervals.
Old Apr 29, 2007 | 03:48 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
1+ srstang
Old Apr 29, 2007 | 12:00 PM
2cokeman's Avatar
2cokeman
Either does ROYAL PURPLE?
Old Apr 29, 2007 | 02:29 PM
howarmat's Avatar
howarmat
s197 Junkie
The extended performance and Royal Purple both are in different classes than the normal mobil 1 I think. That is why they dont meets the same standards
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
