Cure for squeaking poly LCA bushings?
Old May 1, 2007 | 01:26 PM
VWILLO's Avatar
VWILLO
Default Cure for squeaking poly LCA bushings?
Red poly bushings squeaking, have already greased, what are you all doing?
Old May 1, 2007 | 06:10 PM
androdz's Avatar
androdz
I ♥ Acer
Default RE: Cure for squeaking poly LCA bushings?
+1 -.-
Old May 1, 2007 | 06:33 PM
DeStonn's Avatar
DeStonn
Might not be the LCAs. Alot of us have the squeaking and do not have the LCAs. My sound seems like it is coming from the back seat, but it is actually something under the car.
Old May 1, 2007 | 06:46 PM
GT Bob's Avatar
GT Bob
Check the sway bar bushings. Sometimes they can be sqeaky. A little bit of teflon tape or Spray Lithium greaseon the bar where the bushing rides will help stop sqeaking there.
Old May 1, 2007 | 07:35 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Check the UCA as well and make sure all polys are greased!
Old May 1, 2007 | 07:38 PM
northy_polk's Avatar
northy_polk
don't forget to make sure the flux capacitor is set at 1.21 jigga watts or yer SCREWED. i'm not really sure i'm just watching this thread cause i'm installing the BMR relocation brackets and Spohn combo adjustable LCAs in a few weeks. . .
Old May 1, 2007 | 07:43 PM
VWILLO's Avatar
VWILLO
Started squeaking with the LCA install. Bushing have a flange on each side, slightly longer than the inner spacer,that contacts body mounting points.
Old May 1, 2007 | 07:50 PM
northy_polk
those are the ones! please don't take this the wrong way, but did you put them in with thegrease fittingsin the right spot? i only ask because i've heard that some people installed them with the fittings facing the wrong direction. . . could be a source of rubbing/squeaking. . . did you readjust the pinion angle after the install? maybe that could be causing noise. just trying to eliminate potential sources of noise. i have a noise when i slow down coming from the rear driver's side wheel. . . can't find it.
Old May 1, 2007 | 09:10 PM
VWILLO's Avatar
VWILLO
When installing I thought to myself these are going to squeak, because the factory LCAs bushings don't touch the body just the inner spacer does.
Old May 1, 2007 | 09:17 PM
fordfanboy's Avatar
fordfanboy
I ♥ Acer
It may just help someone who knows if you told us what freakin' LCA's you have?
For example - if they are steeda, then throw them away and get something else. The poly eurethane bushing steeda uses are JUNK. They will squeek/rattle a bit and then they will break. Many (more than 5) have broken those bushings. I personally broke them 3 times.
The BMR and Metco are the hands down best IMO. BMR are better constructed all around and the Metco uses a 1/2 poly 1/2 metal bushing that can stand up to just about any torque back there. So again, it will help out a lot if you tell which ones you have cause not all LCA's are created equal?
