Engine Light without a code. What gives?
I searched the forums and found some interseting info concerning my check engine light. I plugged in my scanner and found no codes. I tried to erase any codes as well and the light remains on. About two months ago I added a BBK CAI. I did not get the tuner. The BBK instructions claim that there is a possibility that a code could kick up. They recommend you use higher octane fuel to remedy the code. I filled up with 93 and so far nothing. I read in one of the posts that I searched that the S197 has an advanced PCu that doesn't respond to older OB II scanners. Is this the case? The Owners manual states to check the gas cap. I have and still no loss of the engine light. Car is running superb. Short of taking it to the dealer is there anything anyone can recommend? Thanks.
I think in some cases it can take awhile for the light to clear. I had a throttle body issue and after it was fixed (replaced the whole thing) the light stayed on for about a week (dealership said this was normal).
those lights are for emisssions related problems .if its on theres something wrong if you clear it yourself with a scanner and it returns after a certian number of cycles (ignition on and off) then the problem hasnt been resolved.your car is obd2 so it should read any code .
I have had codes clear on their own and the light stay on. More than likely it's getting a little lean once in a while. If you're going to do anything else to it, invest in a tuner. If you take it to the dealer, be sure to put the stock intake back on first.
ORIGINAL: bomb79
Yes, the S197s use the CAN (Controller Area Network) protocol. Maybe you need to investigate whether your scanner is compliant. If not, then you may be able to upgrade your scanner software depending onthe capability of your particular scanner. If upgrading isn't possible, then you maybe forced to buy a CAN compliant scanner which will be mandatory forall 2008+ vehicles.
ORIGINAL: bodyputtyless
ORIGINAL: Derf00
Silly but basic question. Is yoru scanner compatible with your car? I have a scanner that can read up to 2005 cars. My wife's Escape is 06. It will plug in but gets an error when reading a few of the sensor status'. It's possible your scanner recognizes the car but not the standard that it's being given. Like Lees07GT pointed out, you may need to upgrade the scanner software or buy a new one.
Not silly question at all. I had no idea there was a pending scanner change. Never heard of CAN. And yes, my scanner is not CAN ready. Nor does it have the ability to update. So I'm guessing I have three options. Buy a new scanner and pay the $149 to find out that its running lean due to the BBK CAI. Two, buy a tune and pay another $350 with the possibility of having even more codes jump up. Three, remove the CAI ,sell it, and go back to stock. I only went with the CAI because it dresses up the engine compartment. BBK stated that no tune was needed. (However, you may toss codes. Their remedy is to raise octane). What I don't get is how the thing ran fine without any codes for three months. Then all of a sudden theres to much air. I'm leaning to the care free days of "stock".
ORIGINAL: Derf00
ORIGINAL: Derf00
I'd opt for the new scanner first. It will always come in handy when working on your car and you may find that your problem is not even related to the CAI. You could also go to autozone first and see if their scanner gets a reading. If it does then you know it's scanner incompatiblity, if not, then you may have another problem in which case I'd go to the dealer.
ORIGINAL: Derf00
