engine size
Old May 7, 2007 | 12:32 AM
TinPony's Avatar
TinPony
Default RE: engine size
Bingo slink:: somone must have skipped alot of math classes..
Old May 7, 2007 | 12:51 AM
8cd03gro's Avatar
8cd03gro
to get the "physical size" of the engine, you'd have to do some measuring....nobody rates that. Displacement is actually the volume of air/fuel mixture that is brought into the engine during one cycle. So when the piston is at top dead center, then moves down and the valves open up, however much air is brought in before the piston reaches bottom dead center, multiplied by the number of cylinders, is the displacement of the engine . This is measured in volume of the air at 14.7psi or one atmosphere.
Old May 7, 2007 | 02:11 AM
buddha211's Avatar
buddha211
The math is something like this (I think - its been a while since I've taken a math class):
displacement = pi x r^2 x s x n
where pi is pi (approx 3.14), r is the radius of the cylinder, s is the stroke length (bottom dead center to top dead center) and n is the number of cylinders
It doesn't matter if you measure in inches or centimeters. If you use inches you come up with 281 cubic inches and in centimeters its about 4600 cubic centimeters (4.6L)
To convert between liters and cubic inches is easy 1L = 61.02ci for example 4.6 x 61.02 = 280.69, or rounded, 281 cubic inches
Old May 7, 2007 | 02:16 AM
Herknav's Avatar
Herknav
some people will do ANYTHING for post count...
Old May 7, 2007 | 02:27 AM
ratnacage's Avatar
ratnacage
ORIGINAL: buddha211
Exactly correct.
Do we add the volume of the space remaining in the combustion chamber when the piston is at TDC ?
Old May 7, 2007 | 03:38 AM
Lees07GT's Avatar
Lees07GT
ORIGINAL: ratnacage
ORIGINAL: buddha211
Exactly correct.
No. Displacement is stroke and bore related only, as in the amount of air that is displacedfrom BDC to TDC.
Old May 7, 2007 | 03:52 AM
dirtydeedsinc's Avatar
dirtydeedsinc
I thought the answer was 42.
Old May 7, 2007 | 04:07 AM
buddha211's Avatar
buddha211
ORIGINAL: Herknav
Like make non-thread related comments
Old May 7, 2007 | 04:08 AM
Caution's Avatar
Caution
Wow .. I didn't know any of that as to convert it.. thanks!
ratnacage's Avatar
ratnacage
ORIGINAL: dirtydeedsinc
...sorry for the inconvenience...
