Dennys driveshaft question
Old May 9, 2007 | 05:27 AM
likemike99's Avatar
likemike99
Default Dennys driveshaft question
I just got my Dennys driveshaft in the mail. Boy does it look sweet. But it did not come with the adaptor plate.? Anyone else who has ordered it from them have this problem? is there supposed to be another box?
Old May 9, 2007 | 05:35 AM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Dennys driveshaft question
You miht have the redesigned version without the adapter plate.
Old May 9, 2007 | 06:04 AM
likemike99's Avatar
likemike99
really? their website does not say anything about such possability.
Old May 9, 2007 | 06:41 AM
likemike99's Avatar
likemike99
actually I do see that there are 2 other drive shaft options, I'm guessing it is one of those because it no longer has the 4 bolt holes at the smaller end (transmission end?) it now has one big bolt that I think bolts onto the spindle of the transmission. any ideas if this is righ? do I need to take apart the yolk to do this? what is the torque to tighten it?
[IMG]local://upfiles/52614/8B351F3BCECC44C69DAA2A1050D94D4C.jpg[/IMG]
likemike99's Avatar
likemike99
and did anyone figure out the right grease to use?
Old May 9, 2007 | 07:10 AM
moosestang's Avatar
moosestang
That end bolts to the pinion (rearend), the other end with 4 holes bolts to the transmission. You'll need to remove the pinion nut, which I believe is 1 1/16 inch bolt. Did it come with a new pinion nut?
Anyway make sure you don't pull the slip joint apart or else you'll mess up the alignment of the shaft. That stopped making the adapter plate due to all the problems people were having installing them without vibrations.
You'll need to unbolt the pinion flange from the driveshaft and bolt it to the rear (new driveshaft i'm talking about). Once you remove the stock driveshaft you'll see the large nut that holds the stock pinion flange on there.
Old May 9, 2007 | 07:11 AM
moosestang's Avatar
moosestang
I use valvoline full synthetic wheel bearing/CV joint grease.
ORIGINAL: likemike99
Old May 9, 2007 | 03:16 PM
likemike99's Avatar
likemike99
thanks. yeah after I posted I thought it was for the rear since that is where the adaptor plate was. I just hadn't seen anyone describe this new end. thanks again.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
