Hood Scoop Problem...
Old May 11, 2007 | 12:01 PM
Jizz's Avatar
Jizz
Default Hood Scoop Problem...
I have the Ford installed Hood Scoop on my 2007 GT CS. Seen below
The scoop sticks up off the hood in the rear on the left and right sides --
Anyway to fix this?
Old May 11, 2007 | 12:07 PM
05 Mustang GT's Avatar
05 Mustang GT
Default RE: Hood Scoop Problem...
Get the dealer to repair, its warranty
Old May 11, 2007 | 12:13 PM
GidyupGo's Avatar
GidyupGo
No need for you to have to get your hands dirty on a warranted item, but the studs may just need to be tightened down.
Old May 11, 2007 | 12:35 PM
2cokeman's Avatar
2cokeman
If you look at other 07's they are all not flush with the hood at some point on the scoop!! I bet will be deemed as normal!! Without seeing how bad yours is!
Old May 11, 2007 | 02:24 PM
Jed's Avatar
Jed
All you need to do is git some plastic washers and unscrew the bolts that hold your hood scoop to the hood. I had the same problem [/align]
Old May 11, 2007 | 03:07 PM
Jays Mustang's Avatar
Jays Mustang
I found that scoops take a lot of fitting. Hopefully yours just loosened up.
Old May 11, 2007 | 04:25 PM
Haze28's Avatar
Haze28
ORIGINAL: Jizz
Anyway to fix this?
Your warranty should cover it if it messed up. Just wondering, how did you come up with your name?
Old May 12, 2007 | 04:53 AM
TinPony's Avatar
TinPony
Jed.... can you explain a little more about the plastic washers..... I don't understand.
Old May 12, 2007 | 05:00 AM
Herknav's Avatar
Herknav
hah... hood scoop. Does it put more air into the engine compartment???
Sorry. I am sure you really like the way it looks. More power bro!
Old May 12, 2007 | 05:16 AM
Humboldt Stang's Avatar
Humboldt Stang
Hah...fake gas cap. Does gas really go into the tank from there???
